MQTT failed to start
Posted: Wednesday 13 September 2017 12:59
by mikejclark
Hopefully this should just be a quick question.
I've bought some Sonoff devices and have flashed Tasmota to utilise MQTT.
Following the Domoticz MQTT wiki I have added the MQTT Client Gateway with LAN interface
https://www.domoticz.com/wiki/MQTT
The wiki indicates that all the necessary software is installed with the Domoticz image
Please note that the current Domoticz SDCard image has this included, and you do not need to install any software.
But I see this error:
MQTT: Failed to start, return code: 14 (Check IP/Port)
Is it possible my install is old enough that MQTT was not on the image?
What do I need to do to get MQTT running?
Many thanks!
Version V3.8392
Raspberry Pi
Re: MQTT failed to start
Posted: Wednesday 13 September 2017 13:56
by Logread
not sure about how the images are updated/prepared, but you could try to see if the MQTT broker is listening by issuing this from the shell command line:
if you see something output like:
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN
tcp6 0 0 :::1883 :::* LISTEN
then you have a MQTT broker up and running with websockets enabled... If not you probably want to manually install a MQTT broker such as mosquitto (search the forum for instructions)
Hope this helps
Posted: Wednesday 13 September 2017 14:05
by htilburgs
Just checking to be sure:
- You installed Node.JS ? ->
https://joshondesign.com/2013/10/23/noderpi
- You installed Mosquitto ? ->
http://mosquitto.org/2013/01/mosquitto- ... epository/
- You don't have a firewall that blockes port 1883 ?
- You've checked the remote address and the ip port in Domoticz (Settings - Hardware MQTT Client Gateway)?
- Somethimes it helpes if you change the address from 127.0.0.1 to the real ip of your Domoiticz Host
If all this is checked and still have the error, maybe try the solution in
viewtopic.php?f=6&t=14263&start=20#p144735
Succes!
Posted: Wednesday 13 September 2017 14:52
by mikejclark
Logread wrote: Wednesday 13 September 2017 13:56
- Spoiler: show
- not sure about how the images are updated/prepared, but you could try to see if the MQTT broker is listening by issuing this from the shell command line:
Hope this helps
I will try this when I get home, thanks!
Posted: Wednesday 13 September 2017 14:56
by mikejclark
I haven't installed anything yet, I have the default Domoticz installation from the image, can't remember how long ago. As you suggest, I think I am missing the software you mention. Will try and install later. Thanks!
Posted: Wednesday 13 September 2017 14:58
by htilburgs
mikejclark wrote: Wednesday 13 September 2017 14:56
You write
In the wiki are al the steps you have to follow, including installing Node.JS, installing Mosquitto, etc...
Just follow the wiki and it should be fine.
Posted: Wednesday 13 September 2017 15:21
by mikejclark
I was thrown by the statement about all software being already installed, but I think that must be a recent thing.
Will follow the rest of the wiki and see what happens.
Posted: Thursday 14 September 2017 9:40
by mikejclark
Followed the rest of the wiki and all working well now. Thanks for your help!
Posted: Thursday 14 September 2017 10:58
by htilburgs
Your welcome and succes!
Posted: Thursday 08 December 2022 21:48
by jeroenvd
Strangely 127.0.0.1 or localhost didn't work for me either. Changing to the real IP does the trick for me
