i want save backup database file (.db) with other name
Posted: Friday 08 September 2017 19:09
by reza
hi guys.
i want save backup database with other name. now when i push backup database i have a file with name: domoticz.db
i want save with my name "reza.db" in my computer, which file in source i must change for save backup file with my name?
i dont want save with domoticz and after save rename this . i want save with reza.db.
can you halp me ?
thank you
Re: i want save backup database file (.db) with other name
Posted: Friday 08 September 2017 20:35
by SweetPants
Why do you want this? If you change it in the source, it will be overwritten after the first update. Why not save it and rename it?
Posted: Friday 08 September 2017 20:52
by reza
SweetPants wrote: Friday 08 September 2017 20:35
this is interesting for me that change . now i am change many icons and theme and language etc...
i like learn work with source. now i want learn how save database with this name :domoticz.db . if i want change this , what am i do and after this learning about more option... can you help me ?
reza.db is a example. i am tring to translate domoticz to my language.
Posted: Saturday 09 September 2017 9:01
by SweetPants
reza wrote: Friday 08 September 2017 20:52
Why not write a language pack?
http://www.domoticz.com/forum/viewforum.php?f=7
How do you want to keep up with changes in domoitcz, nobody is going to help you if you have your own 'special' version.
Posted: Saturday 09 September 2017 9:29
by reza
SweetPants wrote: Saturday 09 September 2017 9:01
if i dont update so keep up with changes in domoitcz? is this true ?
i am writing a language But it will take a while, some things can not wirte in language . for example backup name .
Please do not enter into marginal discussions . can you help me for found and change name of download backup database ? which file have name of save and download backup database? thank you
Posted: Saturday 09 September 2017 9:35
by SweetPants
Can't help you with that, you have to search in the source code for that
Posted: Saturday 09 September 2017 9:41
by reza
SweetPants wrote: Saturday 09 September 2017 9:35
i search but dont found this . ok thank you. any body can you help me for found this between source files?
Posted: Saturday 09 September 2017 9:57
by SweetPants
Then you did not search (well)
grep -r domoticz.db
Binary file domoticz matches
main/SQLHelper.cpp: SetDatabaseName("domoticz.db");
main/WebServer.cpp: reply::set_content_from_file(&rep, OutputFileName, "domoticz.db", true);
main/domoticz.cpp:"\t-dbase file_path (for example D:\\domoticz.db)\n"
main/domoticz.cpp:"\t-dbase file_path (for example /opt/domoticz/domoticz.db)\n"
main/domoticz.cpp: std::string dbasefile = szUserDataFolder + "domoticz.db";
main/domoticz.cpp: sPath += "\\domoticz.db";
main/domoticz.cpp: dbasefile = cmdLine.GetSafeArgument("-dbase", 0, "domoticz.db");
Posted: Saturday 09 September 2017 10:31
by reza
SweetPants wrote: Saturday 09 September 2017 9:57
i sse SGLHelper and domoticz in main , but i didnt found webserver in search. i think this is related to this file... thank you very much
