Fetch data from external servers without locking the event system!
Posted: Friday 08 September 2017 17:46
I have seen so many scripts here lately that fetches data from external servers on the Internet.
Most if not all of those scripts use code similar to this:
(Unfortunately even the Wiki is suggesting this method) It's a very bad practice to do like this. The Domoticz event system will wait for the response. That is, with a little bit of bad luck nothing will happen in your Domoticz system for up to 10 seconds.
So, all of a sudden when you least expect it your Domoticz system freezes and you have no clue why. The whole Domoticz system seems unstable and unpredictable. So my advise is to get rid of all those scripts immediately. We all know that there are delays on the Internet ...You can use such scripts in your LAN if you are 100% sure that your LAN servers are up and running 24/7 and always replies very fast.
What can you do about it then?
For a linux system it's not difficult at all to write a script that first calls the url without waiting for the server to respond and then returns one minute later to check the result. Below is a fully working dzVents skeleton script that does exactly that. It calls an URL every 5 minutes. The server is expected to respond with a json and the result is redirected to a temporary file. Then the next minute it checks for the result file and encodes it. Please feel free to use my script.
For the future I'm looking for a way to make the script call a bash script that makes a "call-back" when the external server has responded so that we wouldn't have to wait that extra minute for the result. @dannybloe might have some ideas to to re-trigger the script using a callback, we'll see about that later maybe. But for now I really recommend you to rewrite all your scripts that's using assert(io.popen('curl
Cheers!
local file=assert(io.popen('curl http://someserver.json'))
local raw = file:read('*all')
file:close() So, all of a sudden when you least expect it your Domoticz system freezes and you have no clue why. The whole Domoticz system seems unstable and unpredictable. So my advise is to get rid of all those scripts immediately. We all know that there are delays on the Internet ...You can use such scripts in your LAN if you are 100% sure that your LAN servers are up and running 24/7 and always replies very fast.
-- This example dzVents Lua script shows how to retrieve data from the Internet
-- without risking to lock the Domoticz event system.
local jsonResultFile = '/tmp/tmpJson.json' -- Temporary file to store the servers response
local fetchIntervalMins = 5 -- (Integer) (Minutes, Range 5-60) How often the data shall be retrieved
local scriptVersion = '1.0.2'
active = true,
logging = {
level = domoticz.LOG_INFO, -- Uncomment to override the dzVents global logging setting
marker = 'callNoWait '..scriptVersion
timer = {'every minute'} -- Don't change! Verander niet! Ne changez pas!
-- Every 5 minutes, call the URL and exit.
-- The following minute, return to read the result file
local callUrl = false
if (os.date('*t').min % fetchIntervalMins) == 0 then
callUrl = true
elseif ((os.date('*t').min -1) % fetchIntervalMins) ~= 0 then
return
if callUrl then
local url = 'https://jsonplaceholder.typicode.com/posts/1'
domoticz.log('Requesting data from the jsonplaceholder server...', domoticz.LOG_INFO)
domoticz.log('URL used: '..url, domoticz.LOG_DEBUG)
os.execute('curl -s "'..url..'" > '..jsonResultFile..'&')
return -- Nothing more to do for now, we'll be back in a minute to read the data!
---loads a json file with the provided name and returns it as a table (if it exists)
local function readLuaFromJsonFile(fileName)
local file = io.open(fileName, 'r')
if file then
package.path = './scripts/lua/?.lua;'..package.path
local jsonParser = require('JSON')
local _json = file:read('*a')
local json = jsonParser:decode(_json)
io.close(file)
return json
return nil
local demoData = readLuaFromJsonFile(jsonResultFile)
if not demoData then
domoticz.log('Could not read demoData from file: '.. jsonResultFile, domoticz.LOG_ERROR)
return
domoticz.log('json data file has been read. "title" = "'..demoData.title..'"', domoticz.LOG_INFO)
Cheers!
