Hi everyone.
Today i added the cc2500 on the rflink. Enabled via the tool and status ok. however it dont have the orginal remote voor the ansluta. therefore i try to add the device via the command. when doing it says device created , but its not listed anywhere.
the command is 20;4C;ANSLUTA;ID=d3d2;SWITCH=0;CMD=ON;
Question is if its possible to pair without remote. as the remote needs to be pressed few sec's that is sending the device id to the receiver.
Ansluta command to create device
Re: Ansluta command to create device
small update.. i received beta version rflink v47 that supports pair function. i know can send commands. however when try to add device via rflink with command stil no device is showing under new devices......
It now give me in the log : RFLink: Unhandled switch type
