Raspberry 3 + RaZberry 2 = Fibaro FGD 212 not including
Posted: Wednesday 30 August 2017 12:03
I'm trying to include my new Fibaro FGD 212 but this is not working.
Here is what i've done so far :
When i plug my Fibaro FGD 212 the first time, a green LED lights for few seconds., then a red LED for few seconds., then nothing.
When i push back button for few seconds, a blue LED lights for few seconds.
When i try to include my Fibaro FGD 212, nothing happens.
I've tried to use switch 3 times, use back button 3 times, 1 long time, 3 long time
This is what i see :
Anybody knows how to solve that ?
Thanks for your help
- Fresh install of Raspbian
- Enable SSH
- Fix Raspberry IP to 192.168.1.20
- Connect with SSH to raspberry from another computer :
- mRemoteNG
- user : pi
- password : raspberry
- Chang password for pi user :
passwd - Chang password for root user :
sudo passwd root - Enable root connexion :
sudo nano /etc/ssh/sshd_config- Search : #PermitRootLogin prohibit-password
- Change to : PermitRootLogin yes
- [ctrl] + [X]
- [O]
- [Enter]
sudo /etc/init.d/ssh restart - Update everything :
sudo apt-get updateCode: Select all
sudo apt-get upgrade -yCode: Select all
sudo apt-get install rpi-update -yCode: Select all
sudo rpi-updateCode: Select all
sudo reboot - Disable bluetooth :
sudo sh -c "echo 'dtoverlay=pi3-disable-bt' >> /boot/config.txt"Code: Select all
sudo reboot - Install Domoticz :
sudo wget http://ftp.nl.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u6_armhf.debCode: Select all
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.debCode: Select all
sudo curl -L install.domoticz.com | sudo bashCode: Select all
cd domoticzCode: Select all
sudo ./updaterelease - Connect to Domoticz :
- Set Domoticz :
- Setup > Settings
- To find your location click [Here] > Adress : "Montpellier" > [GetLatLong] > [OK]
- Language : French
- [Apply Settings]
- Setup > Hardware
- Z_WAVE
- Name : Z_WAVE
- Type : OpenZWave
- Serial port : /dev/ttyAMA0
- [Add]
- RFC_COM
- Name : RFC_COM
- Type : RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
- Serial Port : /dev/ttyUSBO
- [Add]
- Z_WAVE
- Setup > Settings
