Looking to combine several LUA scripts for performance. Ideas?
Posted: Sunday 27 August 2017 14:30
As the title says, Looking to get a bit of performance by having less LUA scripts. Quick question about time scripts, does combining them have any performance benefit?
The two scripts for each squeezebox player to get volume status/power etc.. One is for device change and one is time. Please see them below, is it possible to combine all 8 device changes into one LUA script? Many Thanks
if ((devicechanged['Bathroom Radio'] == 'On' or devicechanged['Bathroom Radio'] == 'Playing') and uservariables['BTH'] == 'Off') then
commandArray[#commandArray+1]={['Variable:LTV1'] = 'On'}
--commandArray[#commandArray+1]={['Lounge Touch']='Set Volume 30'}
--os.execute('curl -s "http://192.168.1.26:8080/json.htm?type=command¶m=switchlight&idx=265&switchcmd=Set%20Level&level=30" &')
elseif (devicechanged['Bathroom Radio'] == 'Off' or devicechanged['Bathroom Radio'] == 'Stopped' or devicechanged['Bathroom Radio'] == 'Disconnected') then
if otherdevices['Bathroom Radio V'] ~= 'Off' then
commandArray[#commandArray+1]={['Bathroom Radio V'] = 'Off'}
commandArray[#commandArray+1]={['Variable:BTH'] = 'Off'}
if devicechanged['Bathroom Radio V'] ~= 'Off' and devicechanged['Bathroom Radio V'] ~= nil then
if tonumber(otherdevices_svalues['Bathroom Radio V']) > 0 then
volume = otherdevices_svalues['Bathroom Radio V']
commandArray['Bathroom Radio']='Set Volume '..volume
return commandArrayCode: Select all
if otherdevices['Squeezeboxes'] == 'On' and (otherdevices['Bathroom Radio'] ~= 'Disconnected') then
json = (loadfile '/home/pi/domoticz/scripts/lua/json.lua')()
file = assert(io.popen('curl \'http://192.168.1.26:9000/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["aa:aa:f8:02:4e:bd",["status","-","1",""]]}\''))
raw = file:read('*all')
file:close()
deviceinfo = json:decode(raw)
powerstatus = deviceinfo.result.power
playervolume = deviceinfo.result["mixer volume"] + 1
switchvolume = otherdevices_svalues['Bathroom Radio V']
difference = math.abs(switchvolume - playervolume)
if difference > 1 and tonumber(powerstatus) == 1 then
os.execute('curl -s "http://192.168.1.26:8080/json.htm?type=command¶m=switchlight&idx=361&switchcmd=Set%20Level&level='..playervolume..'" &')
if tonumber(powerstatus) == 1 and otherdevices['Bathroom Radio V'] == 'Off' then
