Weather underground
DewGew
Domoticz version: V4.10618
Weather underground
Post by DewGew »
Hi All,
I can get this code to work in dzVents 2.2.0 any ideas?
I got this error : "Error: dzVents: Error: /home/pi/domoticz/scripts/dzVents/scripts/weather.lua:26: attempt to call a nil value"
fetchWeatherForecast = function()
         json = (loadfile "/home/pi/domoticz/scripts/lua/json.lua")()            --<<Line 26>>--
         local city = "ECDF"
    	 local wuAPIkey = "xxxxxxxxxxx" -- Your Weather Underground API Key
         local file=assert(io.popen('curl http://api.wunderground.com/api/'..wuAPIkey..'/forecast/q/'..city..'.json'))
         local raw = file:read('*all')
         file:close()
         local jsonForecast = json:decode(raw)
         domoticz.data.recentForecast=jsonForecast.forecast.txt_forecast.forecastday[1].fcttext_metric  -- complete forecast
         --domoticz.data.recentForecast=jsonForecast.forecast.simpleforecast.forecastday[1].conditions  -- small forecast
         print("fetchWeatherForecast: " .. domoticz.data.recentForecast)
    end]
// Pierre
Doler
Re: Weather underground
Post by Doler »
I think the error is: json.lua should be JSON.lua. At my system the name of the library is in capitals.
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
DewGew
Post by DewGew »
SO simple..no it works. Thanks #Doler
// Pierre
dannybloe
Post by dannybloe »
Be careful though with doing http requests in your script as it may never complete and will cause your script to be killed after 10 seconds.
BakSeeDaa
Post by BakSeeDaa »
dannybloe wrote: Thursday 24 August 2017 8:01 Be careful though with doing http requests in your script as it may never complete and will cause your script to be killed after 10 seconds.
Yeah true that. Doing like that is devastating, the event system freezes. The whole Domoticz system will appear to be unstable. Some events may even get lost. So take my advice and avoid that disastrous code at all costs.
Instead do something like this:
os.execute('curl -s "'..url..'" > /tmp/resultfile&')
With the ampersand sign at the end of the command the process starts in the background, so the event system can continue and do whatever eventsystems do and won't have to wait until the script is finished.
After a minute let your script look if there is a result file.
EDIT:
Have a look at this topic which gives an example how to do it.
Last edited by BakSeeDaa on Saturday 09 September 2017 10:54, edited 1 time in total.
DewGew
Post by DewGew »
Maybe some should mention this in the wiki also.
http://www.domoticz.com/wiki/Lua_-_json.lua
