Rotary-encoder en Domoticz
rhendriks
Domoticz version: Newest
Post by rhendriks »
I run a dimmer-script with an esp-12 in Domoticz dzEvents.
This works great.
Now I would create an Rotary-encoder on the esp-12 for a wall dimmer ,then I can dim not only with an IPad.
I have connect the Rotary-encoder to the esp and I can see the values in the espeasy-menu.
How can I implement this that it's work with Domoticz?
ommandArray = {}
DomDevice = 'dimmer_1'					---naam van de dimmer zoals deze in domoticz staat
IP = '192.168.1.101'					---ip adres van de esp
Port ='16'								---port van de esp
fade_time ='100'						---laat het dimmen gelijdelijk gaan
	DomValue = (otherdevices_svalues[DomDevice]);
   	---Als in Domoticz op de uit knop gedrukt gaat de waarde van de esp  naar 0
 	if devicechanged[DomDevice] then
   		if(devicechanged[DomDevice]=='Off') then DomValue = 0;
   		print ("Turning off " .. DomDevice);
  		os.execute('curl -s '..(IP)..'/control?cmd=PWM,'..(Port)..',0',(fade_time));
 	---Als in Domoticz op de aan knop gedrukt gaat de waarde van de esp  naar 1
   		if(devicechanged[DomDevice]=='On') then DomValue = 1;
   		print ("Turning on " .. DomDevice);
  		os.execute('curl -s '..(IP)..'/control?cmd=PWM,'..(Port)..',1',(fade_time));
	---Als in Domoticz met de slider wordt bewogen veranderd de dimwaarde
	---Calcvalue = waarde van 0 tot 1023
	---DomValue = waarde van de slider 0 tot 100%
          	CalcValue = DomValue ^ 1.5051;         ---- DomValue ^ logaritmische waarde om de overgang natuurlijker te maken
  		print ("Write value to IP-adres " ..(IP).." Port " ..(Port).." ")
   		print ("Value received from Domoticz was " .. (DomValue) .." ");
  		print ("Calculated value for ESP is " .. (CalcValue) .." ");
  	 	print ("Dimming "  .. (DomDevice) .. " to " .. (CalcValue) .. " ");
		print ("Dimming "  .. (DomDevice) .. " in " .. (fade_time) .. " msec");
    		print(  os.execute('curl -s '..(IP)..'/control?cmd=PWM,'..(Port)..','..(CalcValue)..','..(fade_time)));
frankverd
Re: Rotary-encoder en Domoticz
Post by frankverd »
Hi Rhendriks.
Did you Manage to get it working ?
Kind regars Frank Verdonk
frankverd
Post by frankverd »
Hi Roland.
Maybe you can give me a hint after playing arround for weeks without results connecting a rotary switch to my ESP8266 for dimming function.
The rotery switch is counting up and down in my esp8266 and dimer is working via the slider using you script thank you for that.
But how do i implement the rotary swicth to controle the dimmer funtion.
Thanks in advanced.
I'm using Domoticz
