Lua - loop through devices
tequila
Post by tequila »
I cannot figure out how to loop through devices to determine whether any motion sensor is on (update variable 'PRESENCE_DETECTED' to 'on') or whether ALL of them are off (then I would need to update 'PRESENCE_DETECTED' variable to 'off').
The first part (updating variable to ON if any of the sensors is on) is working fine.
However, I am having issues with the other part - if all sensors are off, then update variable to off
My script:
Devices I need to loop through
--list of all my motion sensors
motion_triggers ={
                    'OB_MS6 - Motion Sensor',
                    'LO_FGMS001 - Sensor',
                    'KP_FGMS001 - Sensor',
                    'CH_FGMS001 - Sensor',
The working part:
for i, motion_trigger in ipairs(motion_triggers) do --loop through motion_triggers
    if devicechanged[motion_trigger] then --any sensor changed
	    if otherdevices[motion_trigger] == 'On' then --any sensor is ON
	        if uservariables['PRESENCE_DETECTED'] ~= 'on' then --only update variable if it is not equal to on (to keep update time)
                commandArray['Variable:PRESENCE_DETECTED'] = 'on' --update PRESENCE_DETECTED variable to ON
            break
How do I modify the code to update the 'PRESENCE_DETECTED' variable to off if all sensors are off?
I have spent all day on this, so any help would be welcome.
DomoFrank
Re: Lua - loop through devices
Post by DomoFrank »
You can try to use this:
local S1 = domoticz.devices.('OB_MS6')
local S2 = domoticz.devices.('LO_FGMS001')
local S3 = domoticz.devices.('KP_FGMS001')
local S4 = domoticz.devices.('CH_FGMS001')
If (S1.state == 'Off' and  S2.state == 'Off' and S3.state == 'Off' and S4.state == 'Off') then 		-- (if all sensors are off...)
	if uservariables['PRESENCE_DETECTED'] == 'On' then
		commandArray['Variable:PRESENCE_DETECTED'] = 'Off'
dannybloe
Post by dannybloe »
Use dzvents. It's trivial to do it.
tequila
Post by tequila »
Thanks DomoFrank,
I actually had a similar script before but wanted to get rid of changing all my IF scripts when adding new sensors to the system.
So I am trying to do this via looping through a list of devices since it is easier when adding new sensors.
Dannybloe, thanks for a tip, I will explore dzvents.
tequila
Post by tequila »
in the end I solved this by using additional virtual switch with off-delay and having another script that based on this virtual switch updates the PRESENCE_DETECTED variable.
I will have a look into dzvents anyway.
Thank you both!
darlomrh
Post by darlomrh »
tequila
Post by tequila »
darlomrh wrote: Sunday 20 August 2017 8:37 Hi,
Would this help?
Interesting! I will definitely have a look.
