Dimmer Mode: Extend Devices attributes stored on User Variable
Posted: Thursday 17 August 2017 12:01
Hello to everyone,
It's been a while since I'm working on domoticz to make my home smart (I live alone, at least one intelligent at home will have to be
I managed through my own web service Vimar By-Me home automation system (it use an IEB bus with a proprietary protocol very similar to KNX).
Everything works well, now I'm trying to increase the functionality by adding a double touch fuction on the wall buttons (standard Vimar) to activate the "double tap mode" (if you tap 2 times ON/OFF Button within two seconds) in addition to the classic ON / OFF buttons, via LUA script.
It already works with scene, with "double tap mode" you can activate a specific scene for ON or OFF button, It's cool
I would like to extend the functionality even in "Dimmer mode", then by pressing the first time in "double mode", set brightness at 25%, then at 50-75-100, at the end of the change cycle, change cold to warm white and vice versa (I have milight lights RGB+CCT).
The only problem in all this it'is know the previous state I was left, I can't see from devicechanged[devicename] or otherdevices[devicename] (there is there another way ??)
So I would to save state when I change it in a user variable string as xml/json/whatever where dynamically set/get the last state set for device.
Do you know some library that I can use (I'm not very practicing in lua), or some other way to do what I want?
I attach part of my actual code if someone is interested.
Thanks a lot, congratulations or great project!
function timedifference(timestamp)
y, m, d, H, M, S = timestamp:match("(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)")
difference = os.difftime(os.time(), os.time{year=y, month=m, day=d, hour=H, min=M, sec=S})
return difference
SecondFunction = {};
SecondFunction[1] = {button="Camera",
SecondFunctionON_Type = "Scene", SecondFunctionON_Action = "Illumina Letto",
SecondFunctionOFF_Type = "Scene", SecondFunctionOFF_Action="Spegni Camera"}
SecondFunction[2] = {button="Living",
SecondFunctionON_Type = "Dimmer", SecondFunctionON_Action = "<none>",
SecondFunctionOFF_Type = "<none>", SecondFunctionOFF_Action=""}
-- verifico tutte le seconde funzioni configurate
for i, v in pairs(SecondFunction) do
if(devicechanged[v.button]) then
if(timedifference(otherdevices_lastupdate[v.button]) < 2 ) then
print("Stato Seconda funzione: "..otherdevices[v.button]);
if(devicechanged[v.button] == "On" or devicechanged[v.button] == "Set Kelvin Level" or devicechanged[v.button] == "Set Level") then
print ("Seconda funzione ON button = ".. v.button ..": Tipo Azione ="..v.SecondFunctionON_Type..", Azione = "..v.SecondFunctionON_Action);
if(v.SecondFunctionON_Type == "Scene") then
print("Attivo Scena = "..v.SecondFunctionON_Action);
commandArray["Scene:"..v.SecondFunctionON_Action] = "On";
elseif (v.SecondFunctionON_Type == "Dimmer") then
--print("Stato attuale: "..devicechanged[v.button]);
if(otherdevices[v.button] == "On") then
commandArray[v.button] = "Set Kelvin Level";
elseif(otherdevices[v.button] == "Set Kelvin Level") then
commandArray[v.button] = "Set Level 75";
elseif(otherdevices[v.button] == "Set Level") then
commandArray[v.button] = "On";
elseif(devicechanged[v.button] == "Off") then
print ("Seconda funzione OFF button = ".. v.button ..": Tipo Azione ="..v.SecondFunctionOFF_Type..", Azione = "..v.SecondFunctionOFF_Action);
if(v.SecondFunctionOFF_Type == "Scene") then
print("Attivo scena "..v.SecondFunctionOFF_Action);
commandArray["Scene:"..v.SecondFunctionOFF_Action] = "On";
elseif (v.SecondFunctionOFF_Type == "Dimmer") then
