hi, i have this situation. light setting as a master (on z-wave device switch). and i can command on or off without problem. actually i export a gpio with sysfs. i create a virtual switch connected on the port 25 export. if i selectet sub/slave i can view a new tab, but i can't chose the master switch.
the fw is 3.8300 beta.
anyone can help me to use the virtual device on gpio port as a slave of the master light as zwave ???
light master and slave
guantolento
- Domoticz version: LastBeta
Master (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
Slave01 (pi2) - MB sensors + Dummy + Weather Underground + 2 FGS223 + 1 FGWPE/F
guantolento
Re: light master and slave
nobody can help me ???
mrf68
shouldn't you select the master switch, then select sub/slave and choose the slave switch?
guantolento
If i choose the sub/slave switch the tab is empty and i can't use any slave switch.
Inviato dal mio GT-I9301I utilizzando Tapatalk
