change status device
krissam44
Post by krissam44 »
May be my question is stupid but I don't find the solution.
How to make the same thing in dzVents than in LUA :
local capteurGlobal = 'Consommation Electrique'
if (devicechanged[capteurGlobal]) then
   -- Do something
capteurGlobal is a OWL CM180+ which sends information around every minutes.
I try this, without any result :
    active = true,
       devices = {
           'Compteur Electrique'
    execute = function(domoticz, compteur)
        if (compteur.changed) then
            domoticz.log('------------------ script newtest -------------------------------------')
            domoticz.log('Reception données OWL')
What am I doing wrong ?
mivo
Re: change status device
Post by mivo »
you need not to check if device changed if (compteur.changed)..., because dzVents checks this for you based on trigger on = { devices = ....
Your script is started only when this device changes.
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
randytsuch
Post by randytsuch »
Also, fyi to use a device in dzvents, you should use in this format
domoticz.devices('Compteur Electrique')
If you search for "The domoticz object" in the dzvents wiki page, it will help show you how to use devices.
krissam44
Post by krissam44 »
Thank you for your help.
The script is functionning, I've just some problems with communication beetween OWL CM180+ and RFXCom.
In normal situation, the CM180 sends information every minute, but sometimes, there is nothing during 20 minutes.
I notice, this situation appears since last beta upgrade of domoticz.
Regards.
