Plugin - Kodi remote
Posted: Sunday 13 August 2017 23:33
Hi all !
I want to display the kodi remote in order to use it with lirc and control my old Samsung TV.
I'm able to have the good switch, but when i click on the remote, nothing happens...
I don't know what's wrong with my code...
Thanks for your help
<plugin key="lirc" name="pilotage via lirc" author="neutrino" version="1.0.0" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://www.google.com/">
<params>
</params>
</plugin>
import Domoticz
import os
import sys
import json
class BasePlugin:
enabled = True
def __init__(self):
#self.var = 123
return
def onStart(self):
Domoticz.Log("onStart called")
if (len(Devices) == 0):
Domoticz.Log("creation")
Domoticz.Device(Name="TVlirc", Unit=1, Type=17,Image=2, Switchtype=17,Used=1).Create()
def onStop(self):
Domoticz.Log("onStop called")
def onConnect(self, Connection, Status, Description):
Domoticz.Log("onConnect called")
def onMessage(self, Connection, Data):
Domoticz.Log("onMessage called")
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
Command = Command.strip()
action, sep, params = Command.partition(' ')
action = action.capitalize()
params = params.capitalize()
if Unit == 1: # TV power switch
if action == "Off":
Devices[1].Update(0, "Off")
elif action == "On":
Devices[1].Update(1, "On")
# Remote buttons (action is capitalized so chosen for Command)
elif Command == "ChannelUp": Domoticz.Log("ChannelUp") # ChannelUp
elif Command == "ChannelDown": Domoticz.Log("ChannelDown") # ChannelDown
elif Command == "Channels": Domoticz.Log("Channels") # Display, shows information on what is playing
elif Command == "VolumeUp": Domoticz.Log("VolumeUp") # VolumeUp
elif Command == "VolumeDown": Domoticz.Log("VolumeDown") # VolumeDown
elif Command == "Mute": Domoticz.Log("Mute") # Mute
elif Command == "Select": Domoticz.Log("Select") # Confirm
elif Command == "Up": Domoticz.Log("Up") # Up
elif Command == "Down": Domoticz.Log("Down") # Down
elif Command == "Left": Domoticz.Log("Left") # Left
elif Command == "Right": Domoticz.Log("Right") # Right
elif Command == "Home": Domoticz.Log("Home") # Home
elif Command == "Info": Domoticz.Log("Info") # EPG
elif Command == "Back": Domoticz.Log("Back") # Return
elif Command == "ContextMenu": Domoticz.Log("ContextMenu") # Options
elif Command == "FullScreen": Domoticz.Log("FullScreen") # Exit
elif Command == "ShowSubtitles": Domoticz.Log("ShowSubtitles") # Input
elif Command == "Stop": Domoticz.Log("Stop") # Stop
elif Command == "BigStepBack": Domoticz.Log("BigStepBack") # Pause
elif Command == "Rewind": Domoticz.Log("Rewind") # Rewind
elif Command == "PlayPause": Domoticz.Log("PlayPause") # TV pause
elif Command == "FastForward": Domoticz.Log("FastForward") # Forward
elif Command == "BigStepForward": Domoticz.Log("BigStepForward") # Play
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Log("onDisconnect called")
def onHeartbeat(self):
Domoticz.Log("onHeartbeat called")
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
