Show current temp/value on homepage
Cribbe
Domoticz version: 3.5866
Post by Cribbe »
I am trying to build a homepage that are made for an old smartphone that will be mounted on the wall.
I want to get current temp from my different temp sensors and perhaps wind and rain sensors as well.
Trying to do this by json but I just get day/month or year and not the just the current value.
Could somebody perhaps help me? Mayby I shall use something else but json?
Egregius
Domoticz version: v2024.7
Re: Show current temp/value on homepage
Post by Egregius »
Json should do just fine. Maybe my PHP Floorplan could give you some ideas? Altough, the current version is totally based on using apcu cache together with pass2php.
Main thing to do is put the devices you want in a roomplan and query that with json.
Loop thru the reply to display the stuff.
Cribbe
Post by Cribbe »
So I must do a roomplan for this? I can´t "just" query current temp by json and print that value on a page?
Egregius
Post by Egregius »
That's the best way because you then only need one api call.
For one device: /json.htm?type=devices&rid=IDX
For all temp devices: /json.htm?type=devices&filter=temp&used=true
For a roomplan: /json.htm?type=devices&used=true&plan=IDX (IDX of the roomplan)
For all used devices: /json.htm?type=devices&used=true
Cribbe
Post by Cribbe »
Well so much I have figured out :-)
But if I for exampel do /json.htm?type=devices&rid=IDX I get a reply with lots of values.
I see that "Temp" is one of them, but I can´t figure out the php code for this to show on my webpage.
For example on the webpage:
Pool - (current temp, json script)
Inside - (current temp, json script)
Outside - (current temp, json script)
Egregius
Post by Egregius »
Give me few minutes to write some code...
Egregius
Post by Egregius »
//Lets grab all temp devices
$domoticz=json_decode(file_get_contents('http://127.0.0.1:8080/json.htm?type=devices&filter=temp&used=true'),true);
//Check if we got a result
if($domoticz){
	//loop thru the result
	foreach($domoticz['result'] as $dom){
		//set a variable with the name
		$name=$dom['Name'];
		//if we have a temp device set a variable with the name of the device with it's value
		if($dom['Type']=='Temp')${$name}=str_replace(' C','',$dom['Data']);
//echo some data on the page. Ex alex_temp is the name of a thermometer
echo '<table>
<tr><td>Alex</td><td>'.$alex_temp.' °C</td></tr>
<tr><td>Tobi</td><td>'.$tobi_temp.' °C</td></tr>
<tr><td>Living</td><td>'.$living_temp.' °C</td></tr>
<tr><td>Kamer</td><td>'.$kamer_temp.' °C</td></tr>
<tr><td>Badkamer</td><td>'.$badkamer_temp.' °C</td></tr>
</table>';
This will print a small table with the values:
Alex	21.1 °C
Tobi	21.1 °C
Living	21.1 °C
Kamer	21.2 °C
Badkamer	21.3 °C
Cribbe
Post by Cribbe »
Got it to work, but got stuck on one sensor that is both temp & humidity.
I´ve tried this:
<?php
$domoticz=json_decode(file_get_contents('http://192.168.1.77:8080/json.htm?type=devices&filter=temp&used=true'),true);
if($domoticz){
		$name=$dom['Name'];
		if($dom['Type']=='Temp + Humidity')${$name}=str_replace(' C','',$dom['Data']);
echo '<table>
<tr><td>Ute</td><td>'.$Ute.' °C</td></tr>
</table>';
But that give me this as result:
Ute 14.2, 71 % °C
I can´t figure out how to give me the result like this (if it is possible):
Ute 14,2 °C, 72% humidity or something similar :D
