Python Plugin: Homepage Counter - Linechart
rwblinn
Domoticz version: 4
Post by rwblinn »
Whilst learning building a Python Plugin (with Domoticz V3.8263) developed a simple Homepage Counter plugin (running on the Raspberry Pi 3 latest Raspian) with a device typename "Counter Incremental". The example widget shows the total hits (1752735) and the hits per day (3). The chart shows the hits per day by hour etc.
Question:
What device can be used and how to define in the plugin to display the total hits (1752735) as a linechart with total hits on the Y-Axis (like f.e. the distance device showing total length in cm/inch). The widget to display the total hits as an int value (and not e notation).
Plugin Code
# Read the content of a homepagecounter text file and display as device
<plugin key="HomepageCounter" name="Homepage Counter" author="rwbl" version="1.0.0" externallink="http://www.rwblinn.de">
    <params>
        <param field="Address" label="URL Homepage Counter" width="300px" required="true" default="http://address/pagecounterfile.txt"/>
        <param field="Mode1" label="Check Interval (seconds)" width="75px" required="true" default="60"/>
            <options>
                <option label="False" value="Normal"  default="true" />
            </options>
        </param>
    </params>
</plugin>
import Domoticz
import urllib
import urllib.request
class BasePlugin:
    enabled = False
    pluginState = "Not Ready"
    def __init__(self):
        return
    def onStart(self):
        if Parameters["Mode6"] == "Debug":
            Domoticz.Debugging(1)
        if (len(Devices) == 0):
            Domoticz.Device(Name="Homepage Counter", Unit=1, TypeName="Counter Incremental", Options={"Counter Incremental": "1;Hits"}).Create()
            Domoticz.Log("Device created.")
            DumpConfigToLog()
        #url = "http..."
        url = Parameters["Address"]
        response = urllib.request.urlopen(url).read()
        Domoticz.Debug("Previous Counter:" + str(response,'utf-8'))
        Domoticz.Heartbeat(int(Parameters["Mode1"]))
    def onStop(self):
        Domoticz.Log("Plugin is stopping.")
    def onHeartbeat(self):
        Domoticz.Debug("onHeartbeat called")
        # Get the url with the text file containing the homepage counter value
        # Open the url and read the content
        # Convert the response from byte to string and strip special characters
        hpc = str(response,'utf-8')
        hpc = hpc.strip(' \t\n\r')
        # Set the new counter as int
        NewCounter = int(hpc)
        # Capture the current sensor value for device with unit = 1
        CurCounter = Devices[1].nValue
        # If first time the CurCounter is 0
        if CurCounter == 0:
            CurCounter = NewCounter
            Devices[1].Update( nValue=NewCounter, sValue=str(NewCounter) )
            Domoticz.Log("HomepageCounter initialized:" + str(NewCounter) )
        # Calculate the delta counter
        DeltaCounter = NewCounter - CurCounter
        # Update the counter if the delta counter > 0
        if DeltaCounter > 0:
            Devices[1].Update( nValue=DeltaCounter, sValue=str(DeltaCounter) )
            Domoticz.Log("HomepageCounter updated by " + str(DeltaCounter) + " to " + str(CurCounter) )
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
    for x in Devices:
        Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
        Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
    return
