SOLVED:- Help with PHP Script
Posted: Wednesday 09 August 2017 18:53
by simon_rb
I have been running the script below for a while now and I didn't realise that the script updates the switch every minute even if its off. So I have over 87K log entries lol
Been trying to find online documentation that allows me to only update switch is its actually Off if its On and switch it On if its Off rather then update it every minute regardless of state.
#!/usr/bin/php
<?php
$ctx = stream_context_create(array('http'=>array('timeout' => 3,)));
$domoticzurl='http://127.0.0.1:8080/';
$denon_address = 'http://192.168.1.12';
$time=$_SERVER['REQUEST_TIME'];
function Schakel($idx,$cmd) {
global $domoticzurl;
$reply=json_decode(file_get_contents($domoticzurl.'json.htm?type=command¶m=switchlight&idx='.$idx.'&switchcmd='.$cmd.'&level=0&passcode='),true);
if($reply['status']=='OK') $reply='OK';else $reply='ERROR';
return $reply;
$denonmain=json_decode(json_encode(simplexml_load_string(file_get_contents($denon_address.'/goform/formMainZone_MainZoneXml.xml?_='.$time,false,$ctx))),TRUE);
if($denonmain['ZonePower']['value']=='ON') Schakel(216,'On');
else Schakel(216,'Off');
Cheers
Re: Help with PHP Script
Posted: Wednesday 09 August 2017 23:03
by pvm
You can first retrieve its value and check before switching
Posted: Thursday 10 August 2017 0:43
by simon_rb
pvm wrote: Wednesday 09 August 2017 23:03
Thats what I plan to do but its been a while and my PHP skills are rather limited.. lol
I assume this will get the result and have to work out how to implement this
$json_string = file_get_contents("http://192.168.1.26:8080/json.htm?type=devices&rid=216");
$parsed_json = json_decode($json_string, true);
$parsed_json = $parsed_json['result'][0];
$stat = $parsed_json['Status'];
echo "Status ".$stat."\n";
Posted: Thursday 10 August 2017 3:57
by Egregius
I see that these are parts of my code
Best option would be to implement my pass2php code because PHP then already knows the status of the switch.
Another option would be to query domoticz for the status before updating it.
Both will work the same, pass2php is very expandable, the second one more limited if you'd like to add stuff later.
Posted: Thursday 10 August 2017 18:41
by simon_rb
Egregius wrote: Thursday 10 August 2017 3:57
More than likely! Any examples of pass2php. I didn't think it would be so involved to add a check before updating! lol
Found this (of yours) and read through it. I understand the principles however just trying to add it to the above code and I'm at a loss lol
https://www.domoticz.com/forum/viewtopi ... 64&t=12343
Posted: Thursday 10 August 2017 22:49
by Egregius
Where are you blocked? At installation of pass2php? Then please respond in that topic.
At integration of pass2php for this issue?
Posted: Saturday 12 August 2017 2:23
by simon_rb
Egregius wrote: Thursday 10 August 2017 22:49
Integration, am I rewriting a whole script or adding it to the above? Please forgive my ignorance. My coding (if you could even call it that) is limited to having examples so I can understand and reuse bits to make it all work. It’s how I learn anyways lol
Posted: Saturday 12 August 2017 7:02
by Egregius
In pass2php this would go in one of the cron scripts:
$denon_address='http://192.168.1.12';
$denon=apcu_fetch('sdenon');
if($denonmain['ZonePower']['value']=='ON'&&$denon!='On')sw('denon','On');
elseif($denonmain['ZonePower']['value']=='OFF'&&$denon!='Off')sw('denon','Off');
Posted: Saturday 12 August 2017 9:32
by PWiAM
I can help with php. I'm net to this forum, what program/script need this code? What is your version of PHP, and what renders it? Also, please provide some of the logs so i know what you're saving.
Let's do some debugging. Look at this code, and do 3 runs. each run wait a bit and note if log has ON, OFF, or ERROR, or missing or syntax error. I note where to comment out by saying FROM HERE and TO HERE so just encapsulate the code withing starting tag "/*" and ending tag "*/".
Like so:
<?php
* FROM HERE
var_dump(['derp' => 'pred']);
* TO HERE
Comment code on designated places and please post results.
#!/usr/bin/php
<?php
$ctx = stream_context_create(['http' => ['timeout' => 3,]]);
$domoticzurl = 'http://127.0.0.1:8080/';
$time = $_SERVER['REQUEST_TIME'];
function Schakel($idx, $cmd)
* comment this block out and tell me if logs updated
* FROM HERE
$reply = json_decode(file_get_contents($domoticzurl . 'json.htm?type=command¶m=switchlight&idx=' . $idx . '&switchcmd=' . $cmd . '&level=0&passcode='), true);
if ($reply['status'] == 'OK') {
$reply = 'OK';
else {
$reply = 'ERROR';
return $reply;
* TO HERE
$denonmain = json_decode(json_encode(simplexml_load_string(file_get_contents($denon_address . '/goform/formMainZone_MainZoneXml.xml?_=' . $time, false, $ctx))), true);
if ($denonmain['ZonePower']['value'] == 'ON') {
* FROM HERE
Schakel(216, 'On'); // seems like if ZonePower is in ON state, this line still puts it on
* TO HERE
else {
* FROM HERE
Schakel(216, 'Off');
* TO HERE
Please post results.
Posted: Saturday 12 August 2017 14:37
by simon_rb
Thanks PWiAM!!!
The script actually runs fine, I just needed to find ways of only updating the switch if it needed updating.
Egregius
Right, so I install pass2PHP and will I then just need that new script above and forget the older/origin one? I am just trying to understand how it works then I can adapt and learn
Thank you!
Posted: Saturday 12 August 2017 17:56
by Egregius
Correct, once pass2php is operational the above script should go in for example __cron60.php to check every minute.
Posted: Sunday 13 August 2017 13:29
by Egregius
Thinks this should do it:
#!/usr/bin/php
<?php
return $reply;
$denon=json_decode(file_get_contents($domoticzurl.'json.htm?type=devices&rid=216'),true);
if(isset($denon))$denon=$denon['result'][0]['Status'];
if($denonmain['ZonePower']['value']=='ON'&&$denon=='Off')Schakel(216,'On');
elseif($denonmain['ZonePower']['value']=='OFF'&&$denon=='On') Schakel(216,'Off');
Posted: Sunday 13 August 2017 14:31
by simon_rb
Egregius wrote: Sunday 13 August 2017 13:29
#!/usr/bin/php
<?php
return $reply;
Thank you. So I have pasted the above in a file called denon_cron60.php and put that in the secure folder. I assume I now have to make sure that executes every minute. How is that achieved ? I also assume I must change you pass2php.php to enter the address of where the secure folder is which contains the denon_cron60.php..
Posted: Sunday 13 August 2017 20:34
by Egregius
Hmmm, this script was intended to run withoit pass2php, so exactly the way how you used to run it.
Posted: Sunday 13 August 2017 20:38
by simon_rb
Egregius wrote: Sunday 13 August 2017 20:34
Oh... Haha!!!!!!
Run it manually and get this
PHP Fatal error: Uncaught Error: Call to undefined function simplexml_load_string() in /home/pi/domoticz/scripts/Denon_Airplay_Check.php:13
Stack trace:
#0 {main}
thrown in /home/pi/domoticz/scripts/Denon_Airplay_Check.php on line 13
I have uncommented extension=php_xmlrpc.dll in the php.ini file
I think PHP 5.6 is still installed - would this need to be removed? does it default to 5.6 instead of 7.0?
Ah, ok. I ran it as PHP7.0 from command line and it worked! Thanks for your help!! Thanks ALOT! Your patience has been amazing!
