sleep/wait in a script?
TheCondor
Post by TheCondor »
Hello, there's nothing similar to a wait or sleep before trigger a switch-on?
I wrote this simple script that turn on the alarm when the tag-presence (a bluetooth beacon) is "out-house" (Fuori) and turn it of when is "in-house" (Casa):
..... ON 'Tag_Andrea' variable state changed......
 if domoticz.variables('Tag_Andrea').value == 'Fuori' then
            domoticz.devices('Pannello Allarme').armAway()
 elseif domoticz.variables('Tag_Andrea').value == 'Casa' then
            domoticz.devices('Pannello Allarme').disarm()
It works fine but i wanna refine more and ad a -wait- or a -sleep- before turn on the alarm for when i'm leaving b house for exable for going in the garden downside or in the card and i'll come back few minutes later.
	 CREATE A LOCAL VARIABLE AND SET IT TO 'FUORI'
	 SLEEP 20 MINUTES
	 IF LOCAL_VARIABLE.STATE == domoticz.variables('Tag_Andrea').state then
         ELSE DO NOTHING BECAUSE I'M IN HOUSE AGAIN
Any suggest? Thanks in advance for your kind help!
freijn
Domoticz version: Stable
Re: sleep/wait in a script?
Post by freijn »
What about this ( as you are thinking in minutes )
Set a variable when the trigger starts. Variable can contain a timestamp
Check every minute if this variable is still "hot" then after 5 min difference ( current_time-Var_time > 5 ) you activate the alarm.
jvandenbroek
Post by jvandenbroek »
Not checked / tested it myself, but can't you just use armAway().afterMin(20)?
heggink
Domoticz version: 12451
Post by heggink »
AfterSec and such work. Used it myself. Please note that there is the delay in settings that is also used. Please also note that during the delay, domoticz.security will already say "armed..". Have a look at the new dzvents proposed alarm scripts.
P1 meter & solar panel
TheCondor
Post by TheCondor »
current_time - Var_time could work... AfterSec is triggered in "advance" and cannot be deleted if an opposite event is triggered.
I explain better:
if TAG_PRESENCE = OUT then
security.panel = ON after 2 minute <---- (it will be turned on after 2 minute anyway, also if TAG_PRESENCE will turn = IN before the 2 minute delay).
So, if i understood well the AfterSec the only way is trough a local variable of a time difference. But maybe this could be integrated in DZVENTS next build with a SLEEP XX SECONDS to write -BEFORE- the SecurityPanel = ON command and recheck again the TAG_PRESENCE and if still = OUT THEN, and only now, turn on the alarm. This could be useful in other situations obviously....
heggink
Post by heggink »
So you're saying that an armAway.Aftersec(90) still arms even if within the 90 secs a disarm is done? That's not helpful...
jeanclic
Post by jeanclic »
I'm wokring on an alarm script, and I have seen a lot of topics talking about this delay "issue" (I mean the security state beeing "Armed" immediately despite the delay in the settings).
I have seen a lot of scripts defining a variable containing a time to delay the actions.
Would it not be easier to have a mean via dzVents to access the domoticz settings, and so get the time directly from the settings ? (accessible via /json.htm?type=settings -> item "SecOnDelay") ?
Maybe it is already the cas,but I did not found it...
-> begining with this info, I assume it would be easy to have the "alarm" script acting only when "Armed" for at least the time in settings ?
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
