I get on my way slowly. Have already made various scripts and blocky's.
Pushover also works but I have a question about how I get telegram (bone) method working.
Does this work in the same way as in SH?
curl --data chat_id=19959367 --data-urlencode "text=Some complex text $25 78%" "https://api.telegram.org/bot_mijn code/sendMessage?chat_id=Mijn_id&text=Er is aangebeld!"
Using Telegram
randytsuch
Re: Using Telegram
Did you try something like this?
I haven't used telegram so I don't know the specifics of using it
os.execute('curl command to send telegram .....')-
bing69
Re: Using Telegram
Thanks, but that not worksrandytsuch wrote:Did you try something like this?
I haven't used telegram so I don't know the specifics of using itCode: Select all
bing69
Re: Using Telegram
Thanks !, The same syntax (except extra ") as in LUAMilifax wrote:
https://www.domoticz.com/wiki/Telegram_Bot
