Hi all
simple question as i'm struggling to find a clear info.
i would like to check a device using it's idx instead of it's name, is it possible in LUA ?
otherwise is it possible to assign the name of a device to a variable and use this variable in the script instead of repeating the device name ?
idea is just to avoid many changes when i change the name of a device.
thnaks !
seb
Use IDX instead of device name in LUA ?
sebitop
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
sebitop
Re: Use IDX instead of device name in LUA ?
I found part of the answer
one idea is to set a local var with your device name
local variable = "name of the device"
then you can use commandArray[variable]='On' for exmaple to whitch on your device
- sisaenkov
- Domoticz version: 3.8
Try this:
function getdevname4idx(deviceIDX)
for i, v in pairs(otherdevices_idx) do
if v == deviceIDX then
return i
return 0
commandArray[getdevname4idx(383)] = 'On'
- McMelloW
- Domoticz version: V2024.1
Try to use dzVents for Lua and idx for devices as well. See this wiki page http://www.domoticz.com/wiki/DzVents:_n ... _scripting.
Greetings McMelloW
