LUA: bad argument #1 to 'read' (invalid format)
Posted: Sunday 06 August 2017 9:40
by puttemanp
Good morning all,
After upgrading to V3.8153 I have the folowing error in my logfile upon calling a LUA script: bad argument #1 to 'read' (invalid format)
--|1502624.00
print ('Script Water Started')
local thisfilename = "/home/pi/dev-domoticz/scripts/lua/script_device_water.lua"
local virtualcounter_idx = "53"
local switchName = "water"
if devicechanged [switchName] == 'On' then
-- Open this file and read the first line
        file = io.open (thisfilename, "rb")
        sContents = file:read ("*1")
        file:close()
-- Parse and update the countvalue
        foo,snumber = sContents:match("([^,]+)|([^,]+)")
        local countvalue = snumber + 0,50
        local newline = foo .. "|" .. string.format("%.2f", tostring (countvalue))
-- Update virtual counter device
        ts = virtualcounter_idx .. "|0|" .. string.format("%2.f",tostring(countvalue))
        commandArray['UpdateDevice'] = ts
-- Write back new counter value
        local file = io.open(thisfilename, "r+")
        file:write(newline)
        file:close()
This script used to run correctly before, it's only after the upgrade to the latest version (compiled from source as I had to make modifications for Nest Field Test compatibility).
Any insights as I don't seem to find this specific error on the board or using Google.
Thx
P.
Re: LUA: bad argument #1 to 'read' (invalid format)
Posted: Sunday 06 August 2017 10:21
by jvdz
Is "rb" correct for io.open? Can't find the b option in the manual I have.
It also has the filename thisfilename, which is the script file?
Jos
Posted: Sunday 06 August 2017 10:30
by puttemanp
Honestly, I'm a noob where Lua is concerned. All I know is that untill the day before yesterday, the script worked. Upgraded and the error appeared, counter is not updated anymore.
The original script can be found in another thread : https://www.domoticz.com/forum/viewtopi ... 306#p61306
I merely adapted it for my use 2 years ago.
Greetz
P.
Posted: Sunday 05 November 2017 15:31
by mauip
Hi there,
i kindly ask you for help-i am totaly new to lua and domoticz.
I tried to use the scripts provided on the link below:
https://www.domoticz.com/wiki/ESP8266_WiFi_module
but i get always an error on the t=ds18b20.read() in the domoticz.lua script. (domoticz.lua:7: bad argument #1 to 'read' (Must be function)
I am using a ESP8266-01 with the following Firmware:
NodeMCU custom build by frightanic.com
branch: master
commit: 443e8219527f5b2190324a969a4586f9d3d731bf
SSL: false
modules: bme280,cron,dht,ds18b20,encoder,enduser_setup,file,gpio,http,net,node,ow,rtcfifo,rtctime,sjson,spi,tmr,uart,websocket,wifi
build built on: 2017-11-02 22:02
powered by Lua 5.1.4 on SDK 2.1.0(116b762)
Many thanks for your Support.
