first script to control lamps when im watching TV
Posted: Saturday 05 August 2017 10:05
by markjgabb
Hi guys
this is my first script to control a set of milights in my lounge room when diffrent actions occur on the TV
i get an error about expected actions on line 35
im really no programer at all.....
anyone alble to just highlight what i need to change?
any improvement suggestions are appriciated
-- Check the wiki at
-- http://www.domoticz.com/wiki/%27dzVents%27:_next_generation_LUA_scripting
	-- 'active' controls if this entire script is considered or not
	active = true, -- set to false to disable this script
	-- trigger
	-- can be a combination:
		devices = {
			-- scripts is executed if the device that was updated matches with one of these triggers
			'Lounge Kodi', -- kodi media centre in Lounge
		timer = {
		    'at nighttime',
	-- actual event code
	-- in case of a timer event or security event, device == nil
		The domoticz object holds all information about your Domoticz system. E.g.:
		local myDevice = domoticz.devices('myDevice')
		local myVariable = domoticz.variables('myUserVariable')
		local myGroup = domoticz.groups('myGroup')
		local myScene = domoticz.sceneds('myScene')
		The device object is the device that was triggered due to the device in the 'on' section above.
		-- example
		if ('Lounge Kodi'.state == 'Video') then
			domoticz.setScene('TV Playing', 'On')
			domoticz.notify('Lounge kodi', 'mood lights on')
		elseif ('Lounge Kodi'.state == 'Paused') or (device.state == 'on') then
		    domoticz.setScene('Lounge Normal Lights', 'On')
Re: first script to control lamps when im watching TV
Posted: Saturday 05 August 2017 10:35
by BakSeeDaa
Hi.
Try changing
'Lounge Kodi'.state
to
device.state
Remove the comma sign at the end of the code.
Remove the timer trigger, you probably do not want it. However you might want to limit the script to do anything in daytime?
Then You can put a time rule constraint on the device trigger. That is, change
into
['Lounge Kodi'] = 'at nighttime', -- kodi media centre in Lounge
Posted: Saturday 05 August 2017 10:56
by markjgabb
yeah that was my plan....i or wil lthat make it go very minute during nighttime?
im now getting the following
dzVents: Error: An error occured when calling event handler Lights on TV Actions
2017-08-05 18:55:00.081 Error: dzVents: Error: ...ripts/dzVents/generated_scripts/Lights on TV Actions.lua:35: attempt to index local 'device' (a nil value)
Posted: Saturday 05 August 2017 11:20
by markjgabb
thanks heaps...removing the timer part has stopped the error....i think if i can get a few more scripts running with help i should be able to wrap my head around this... i love the idea of event only evaluating on speciifc predefined actions...that part of this is brilliant...then on top of that having and if statement ability should be great
Posted: Saturday 05 August 2017 11:54
by markjgabb
is this a valid statement
elseif domoticz.time.isNightTime and ((device.state == 'Paused') or (device.state == 'on')) then
so i would like it run on if its night time and one of those two is true....?
