Wrong battery level for a new device
BakSeeDaa
Post by BakSeeDaa »
Hi there, it's me again. :oops:
I added a new Fibaro Wall plug FGWPF-102-ZW5 to my system a few days ago.
I started to get messages about low battery level for this device and it's not accurate because it's mains powered.
Here is the Domoticz device listing:
   "ActTime" : 1501824965,
   "ServerTime" : "2017-08-04 07:36:05",
   "Sunrise" : "05:16",
   "Sunset" : "21:15",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 4,
         "HardwareName" : "ZWaveUSB",
         "HardwareTypeVal" : 21,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "00006701",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-08-04 06:54:53",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "Sovrumsfläkt",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "611"
   "status" : "OK",
   "title" : "Devices"
And here is the dzVents debug entry:
[191] = {
		["switchType"] = "On/Off";
		["timedOut"] = false;
		["description"] = "";
		["rawData"] = {
			[1] = "0";
		["name"] = "Sovrumsfläkt";
		["switchTypeValue"] = 0;
		["data"] = {
			["levelVal"] = 0;
			["hardwareID"] = 1872875856;
			["icon"] = "lightbulb";
			["_state"] = "Off";
			["protected"] = false;
			["_nValue"] = 0;
			["unit"] = 1;
			["hardwareType"] = "OpenZWave USB";
			["maxDimLevel"] = 100;
			["hardwareTypeValue"] = 21;
			["hardwareName"] = "ZWaveUSB";
			["usedByCamera"] = false;
		["baseType"] = "device";
		["deviceType"] = "Light/Switch";
		["id"] = 611;
		["deviceID"] = "";
		["changed"] = false;
		["signalLevel"] = 1992167424;
		["batteryLevel"] = 0;
		["lastLevel"] = 0;
		["lastUpdate"] = "2017-08-04 06:54:53";
		["subType"] = "Switch";
For reference, below is another Fibaro wall plug:
	[121] = {
		["rawData"] = {
			[1] = "0";
		["name"] = "Alarm Status Indicator";
		["data"] = {
			["levelVal"] = 0;
			["hardwareID"] = 4;
			["_state"] = "On";
			["_nValue"] = 1;
			["unit"] = 1;
		["id"] = 454;
		["deviceID"] = "00006201";
		["signalLevel"] = 12;
		["batteryLevel"] = 255;
		["lastLevel"] = 0;
		["lastUpdate"] = "2017-08-04 06:54:54";
Strange isn't it?
dannybloe
Re: Wrong battery level for a new device
Post by dannybloe »
I don't know why this is. The batterylevel comes straight out of the database I think and is then handed to the event system. I do know that when it is 255 it is not-applicable for that device. So in the generic device adapter in dzVents I only create a batteryLevel if it has a value less than or equal to 100 (it's a percentage after all). If it is higher it is nil (not existing).
BakSeeDaa
Post by BakSeeDaa »
dannybloe wrote:I don't know why this is. The batterylevel comes straight out of the database I think and is then handed to the event system. I do know that when it is 255 it is not-applicable for that device. So in the generic device adapter in dzVents I only create a batteryLevel if it has a value less than or equal to 100 (it's a percentage after all). If it is higher it is nil (not existing).
Thanks @dannybloe
This is not a battery level issue. The data parameter supplied to the function in the generic device adapters is not complete. For example the data.deviceID is an empty string and the hardwareID 1872875856 is wrong. The device seems to have proper values when looking at it in the Domoticz device manager though. Please let me know if you have any idea about how to debug it further.
