PIR/Dimmer not working anymore? Dzvents/Lua?
BarryT
Domoticz version: 2024.3
Post by BarryT »
Several days ago, i used a beta update that has the lua scripting and stuff changed to dZvents (as seen in the log), but after today not all of my lua scripts are working anymore and it seems the update (of today) has gone back to lua instead of dZvents?
Everything was working since today!
My (motion) lights are not working anymore!
Help.. Its getting dark in here!
This is one of my lua:
if (devicechanged['Beweging Hal Beneden'] == 'On' and otherdevices['Het is Donker'] == 'On' and otherdevices['Lamp Hal Beneden'] == 'Off') then
   commandArray ['Lamp Hal Beneden']= 'Set Level 80'
  print('Beweging in de hal, lampen aan want het is donker!')
if (devicechanged['Beweging Hal Beneden'] == 'On' and otherdevices['Het is Donker'] == 'Off' and otherdevices['Lamp Hal Beneden'] == 'Off') then
   commandArray['Lamp Hal Beneden']='Off'
  print('Beweging in de hal, maar lampen blijven uit want het is nog licht!')
if (devicechanged['Beweging Hal Beneden'] == 'Off') then
          commandArray['Lamp Hal Beneden'] = 'Off'
    print('Beweging in de hal UIT signaal ontvangen')
dannybloe
Re: PIR/Dimmer not working anymore? Dzvents/Lua?
Post by dannybloe »
I think it is fixed in the latest beta.
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
see:
https://www.domoticz.com/forum/viewtopi ... =6&t=18668
same problems
Gizmocuz is fixing it
Jan
gizmocuz
Post by gizmocuz »
Should be fixed now
BarryT
Post by BarryT »
gizmocuz wrote:Should be fixed now
Thanks guys!
What was the fix?
*Edit, nevermind.. seen it in the forum :)
