Logging
jkimmel
Domoticz version: 2021.1
Logging
Post by jkimmel »
Despite LOGGING = true there is no logging found. Where to set log level?
Rfxcom
Raspi 4
Doler
Re: Logging
Post by Doler »
In Settings - Other:
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
jkimmel
Re: Logging
Post by jkimmel »
But this enabled doesn't show anything (LOGGING = true) having this code
if LOGGING then domoticz.log('Setpoint was set to ' .. device.state) end
Rfxcom
Raspi 4
Doler
Re: Logging
Post by Doler »
Log level must be set to ' Errors + minimal execution info + general info' in order to see the log messages.
jkimmel
Re: Logging
Post by jkimmel »
Doler wrote:Log level must be set to ' Errors + minimal execution info + general info' in order to see the log messages.
Thank you!
Rfxcom
Raspi 4
dannybloe
Re: Logging
Post by dannybloe »
It is best to explicitly pass a log-level to the log method in your code:
domoticz.log('Some message', domoticz.LOG_INFO) -- or LOG_ERROR or LOG_DEBUG
That way you have full control of when you want to see which kind of log messages using the settings.
