dzVents not triggering on device indexes
BakSeeDaa
Post by BakSeeDaa »
dzVents 2.2.0, Domoticz V3.8143 @ rpi3
The following script won't trigger on a device with idx 596:
	active = true,
	logging = {
		level = domoticz.LOG_INFO, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
		marker = "TEST"
		devices = {
			596,
		domoticz.log('Triggered by device: '..device.name, domoticz.LOG_INFO)
		domoticz.log('Device state: '..device.state, domoticz.LOG_INFO)
		domoticz.log('Device lastUpdate.raw: '..device.lastUpdate.raw, domoticz.LOG_INFO)
Changing 596 to the device's name makes the script trigger properly.
dannybloe
Re: dzVents not triggering on device indexes
Post by dannybloe »
Ok, can you try this: turn dzVents into debug logging mode (domoticz settings, not just this script!). Then trigger this device. Then paste all the logging dzVents does. Also find the part in scripts/dzVents/domoticzData.lua that lists this device and paste it here as well.
BakSeeDaa
Post by BakSeeDaa »
I think I found something usable...
My test script will trigger on the device id only if there are no other scripts that's triggers on the same device's name.
E.g. if I remove "A580 IP" from my radio.lua script, my testa.lua script can trigger on the device using it's id (596). Does that make any sense? Do you still need the debug output?
dannybloe
Post by dannybloe »
Aha.. I must have done that on purpose. But it sucks indeed.
/me will investigate
dannybloe
Post by dannybloe »
Ok, I think I have a fix (for 2.2.1). Could you try my fix? Locate the file EventHelpers.lua in scripts/dzVents/runtime and replace it with the attached version. (copy the current version first).
Let me know if that fixes the problem for you.
Cheers,
Danny
EventHelpers.lua.zip
(5.04 KiB) Downloaded 123 times
BakSeeDaa
Post by BakSeeDaa »
I will try it when I get home later.
BakSeeDaa
Post by BakSeeDaa »
Problem is solved!
:¦:-•:*"*:•.-:¦:-•*EXCELLENT WORK!*•-:¦:-•:*'''*:•-:¦:-THANKS*•-:¦:-•:*''**•
dannybloe
Post by dannybloe »
Cool, then I'll commit it.
BakSeeDaa
Post by BakSeeDaa »
dannybloe wrote:Cool, then I'll commit it.
I believe it's still not changed in Domoticz version 3.8153 (Stable). Will the attached file work for the new Domoticz version to?
dannybloe
Post by dannybloe »
True.. it will be in 2.1.1. Dunno when it will be in the beta.
But you can use the attached file without problems.
