Hi Guys,
I have a motorized curtain from autogordijn.
I want to implement the control in Domoticz so I can close and open the curtains on light (luxlevel)
For this reason I need a switch with 3 switches inside (open, close and stop)
They also need to be potential free.
Anyone any idea as if such a switch is available.
Jan
Z-wave switch with 3 switches inside
JuanUil
- Domoticz version: 4.11083
JuanUil
Re: Z-wave switch with 3 switches inside
Of course I could do it with a 2 relay and a 1 relay switch of Fibaro because they are potential free.
but I think that is an expensive way
Jan
Jan
tlpeter
Can you use a Fibaro roller/shutter module?
It keeps providing power untill the end or back to the begin and should support a stop button now.
Or does your curtain have wires for that?
Can you post a picture?
JuanUil
Hi Tlpeter,
thnx for your reply.
I had thought of that as wel but the roller shutter is not potential free.
I have 4 wires for the motor.
1 common
1 close
1 open
1 stop
so common and closed connected (for max 1 sec.!!) closes the curtain.
greetings
Jan
1 common
1 close
1 open
1 stop
greetings
Jan
tlpeter
What do you already have within Domoticz?
Maybe you can do this with MySensors?
I have what I term as unrivalled customized curtain from https://hovement.com/best-curtains-for-living-room/. As far as this query is concerned, I think it's possible to do it with a 1 relay switch that's potentially free. I'm now possible to have my curtains close and open on light. Unless I contact the dealers, I'm not in a position to advice on the availability of the wires nor the related switches. Will be posting my pics. once I'm home.tlpeter wrote: Thursday 27 July 2017 7:44 Can you use a Fibaro roller/shutter module?
