Neo Coolcam flood sensor
petzno
Post by petzno »
I just included one of these to Domoticz:
https://www.aliexpress.com/item/NEO-COO ... 0.0.dUNXgw
It does not seem to show the battery level in Domoticz, although I can find it in OpenZwave control panel so it is supported by the device. Anyone been able to get battery status for this flood sensor in domoticz?
LouiS22
Re: Neo Coolcam flood sensor
Post by LouiS22 »
Yes, it's there.
petzno
Post by petzno »
Seems like it arrived today after the 12h update interval.
The attached shows what the flood sensor is presenting. Seems like several of them is able to act as the alarm switch?
remb0
Post by remb0 »
But I don't think it works: My sensor is 7 months online but still 100 percent :P
LouiS22
Post by LouiS22 »
remb0 wrote:But I don't think it works: My sensor is 7 months online but still 100 percent :P
Yeah I noticed with other sensors - even with Fibaro, so it's not a cheap chinese problem. Also: haven't found a proper solution :(
petzno
Post by petzno »
If the sensor is not activated too much it could still be showing 100% even after months. As mentioned here this also applies to Fibaro. The problem is that suddenly they are dropping fast.
EddyG
Post by EddyG »
In the previous stable version of Domoticz it showed 100%. In the current version V3.8153 it does not show any battery level.
I have a Domux DX1SA-Z which shows 98% in de OpenZwave Control panel, but nothing is showed in Domoticz.
Does anyone knows a manual way to interrogate a RaZberry ZWave devices to see if data is send?
