Page 1 of 2
Unifi controller - Presence detection
Posted: Monday 24 July 2017 16:24
by vrmp
I created a LUA script to read the Unifi controller for a specific device name and report the status.
Perhaps someone else has some use for it aswell.
The Function:
function UnifiController(Username)
	unifi_username = "admin" -- Username for example admin
	unifi_password = "admin123" -- Password for example 1234546
	unifi_controller_ip = "192.168.0.2" -- Controller IP for example 192.168.0.2
	unifi_controller_port = "8443"  -- Controller port, default is 8443
	cookie = "/tmp/unifi_cookie_lua" -- Temp cookie file
	tempfilename = "/tmp/UnifiController.tmp" -- Temp JSON output file
	local f = io.popen("stat -c %Y " .. tempfilename)
	local last_modified = f:read()
	if (os.difftime (os.time(), last_modified) > 30)
	then
		-- URL for logging in, query and logging out
		url_login = 'curl --cookie ' .. cookie .. ' --cookie-jar ' .. cookie .. ' --insecure -H \'Content-Type: application/json\' -X POST -d \'{"password":"' .. unifi_password .. '","username":"' .. unifi_username .. '"}\' https://' .. unifi_controller_ip .. ':' .. unifi_controller_port .. '/api/login'
		url_open = 'curl --cookie ' .. cookie .. ' --cookie-jar ' .. cookie .. ' --insecure -s -o '..tempfilename..' --data "json={}" https://' .. unifi_controller_ip .. ':' .. unifi_controller_port .. '/api/s/default/stat/sta'
		url_logout = 'curl --cookie ' .. cookie .. ' --cookie-jar ' .. cookie .. ' --insecure https://' .. unifi_controller_ip .. ':' .. unifi_controller_port .. '/logout'
		-- Execute url
		-- Execute url
		read_login = os.execute(url_login)
		read_open = os.execute(url_open)
		read_logout = os.execute(url_logout)
	file = io.open(tempfilename, "r")
	while true do
		line = file:read("*line")
		if not line then break end
		if string.find(line, Username)
		then
			UnifiResult = "Home"
			UnifiResult = "NotHome"
	file:close()
	return UnifiResult
An example:
--Example
TestUser = "Domoticz"
print(TestUser .. ": " .. UnifiController(TestUser))
The status will be "Home" or "NotHome" and I use this to set a virtual device to on or off.
Re: Unifi controller - Presence detection
Posted: Friday 11 August 2017 22:19
by DomoFrank
I would really like to use this function in my Domoticz. I'm not very experienced with LUA, can you explain me how I can implement this?
I did create a User Variable 'UniResult' and I've copied your function to a LUA script and call the function in a dzVents like this:
    active = true,
		timer = {
			'at 15:14'
    execute = function(domoticz)
        local TestUser = "iphone"
        UnifiResult = UnifiController(TestUser)
        print(TestUser .. ": " .. UnifiResult)
I use a timer to test the script, finally I will connect it to a dummy device/switch.
But I get 2 Errors:
2017-08-11 22:16:00.335 dzVents: Info: ------ Start internal script: HomeTest:, trigger: at 22:16
2017-08-11 22:16:00.335 Error: dzVents: Error: An error occured when calling event handler HomeTest
2017-08-11 22:16:00.335 Error: dzVents: Error: .../domoticz/scripts/dzVents/generated_scripts/HomeTest.lua:10: attempt to call global 'UnifiController' (a nil value)
2017-08-11 22:16:00.335 dzVents: Info: ------ Finished HomeTest
2017-08-11 22:16:00.336 Error: EventSystem: Lua script UnifyController did not return a commandArray
What am I doing wrong?
Posted: Saturday 12 August 2017 0:09
by vrmp
I'm not using dzvents but the normal lua code.
When you separate the function to a different file using dzvents you should use the helper function:
https://github.com/dannybloe/dzVents/issues/28
Perhaps you can also place the function in your dzvents code block, but I'm not sure of that.
Posted: Saturday 12 August 2017 13:53
by JimmyH1969
Does not seem to work on my system, this is what i see in the log
2017-08-12 13:46:49.188 Error: EventSystem: in Unify: [string "function UnifiController(Username) ..."]:26: attempt to index global 'file' (a nil value)
That's like it cant open/create a file i think?
I'm running Domoticz on a Windows 7 system and have Curl installed, could Windows be the cause?
Posted: Saturday 12 August 2017 14:08
by vrmp
That could be the problem. Did you replace these settings with a valid path on your Windows system?
Posted: Sunday 13 August 2017 18:04
by JimmyH1969
Changing it to a valid path works, but now i'm getting this message in the UnifiController.tmp
{ "data" : [ ] , "meta" : { "msg" : "api.err.LoginRequired" , "rc" : "error"}}
Posted: Sunday 13 August 2017 18:19
by vrmp
Is the file in the cookie variable also created?
Without this file the login would fail as you describe.
Can you check that?
Posted: Sunday 13 August 2017 18:28
by JimmyH1969
yes it is, the contents:
# Netscape HTTP Cookie File
# https://curl.haxx.se/docs/http-cookies.html
# This file was generated by libcurl! Edit at your own risk.
Posted: Sunday 13 August 2017 19:03
by vrmp
Can you remove the logout part from the function and try again?
Posted: Sunday 13 August 2017 19:46
by JimmyH1969
That results in the same error in the UnifiController.tmp
If i remove the second line
and only leave the first line, the "UnifiController.tmp" is not created or modified. I guess there is something wrong with the first line.
If i start that command from a prompt, like this:
curl --cookie unifi_cookie_lua --cookie-jar unifi_cookie_lua --insecure -H 'Content-Type: application/json' -X POST -d '{"password":"admin","username":"admin"}' https://192.168.1.12:8443/api/login
Then the result is:
curl: (6) Couldn't resolve host 'application'
{ "data" : [ ] , "meta" : { "msg" : "api.err.Invalid" , "rc" : "error"}}
Posted: Sunday 13 August 2017 19:51
by vrmp
Can you replace the ' with " in you manual command?
I think Windows does not recognize this and assumed after the space the next option is given, which is application in this case.
Posted: Sunday 13 August 2017 21:37
by JimmyH1969
I tried and get this.
I do think it's a commandline issue. I just can't seem to get the command right :x
Posted: Sunday 13 August 2017 21:39
by vrmp
I will have a look at it tomorrow on a Windows system
Posted: Sunday 13 August 2017 21:42
by JimmyH1969
Thanks, would be great to have this working. :D
Posted: Sunday 13 August 2017 21:56
by vrmp
Can you try this
curl --cookie unifi_cookie_lua --cookie-jar unifi_cookie_lua --insecure -H "Content-Type: application/json" -X POST -d "{\"password\":\"admin\",\"username\":\"admin\"}" https://192.168.1.12:8443/api/login
Posted: Monday 14 August 2017 17:19
by JimmyH1969
tried, no succes :?
Posted: Monday 14 August 2017 17:35
by vrmp
I check some stuff and this works for me on my Windows system:
curl --cookie unifi_cookie_lua --cookie-jar unifi_cookie_lua --insecure -H "Content-Type: application/json" --data "{\"password\":\"admin\",\"username\":\"admin\"}" https://192.168.1.12:8443/api/login
curl --cookie unifi_cookie_lua --cookie-jar unifi_cookie_lua --insecure -s -o test.txt --data "json={}" https://192.168.1.12:8443/api/s/default/stat/sta
This should create a file test.txt with the JSON output as expected.
Can you make the needed changes for you Windows system in the function to create the above yourself or can I help you with it?
Nevermind, here it is:
url_login = 'curl --cookie ' .. cookie .. ' --cookie-jar ' .. cookie .. ' --insecure -H "Content-Type: application/json" --data "{\"password\":\"' .. unifi_password .. '\",\"username\":\"' .. unifi_username .. '\"}" https://' .. unifi_controller_ip .. ':' .. unifi_controller_port .. '/api/login'
Hopefully it will work now on your system :D
Posted: Tuesday 15 August 2017 9:53
by parkerc
Thanks so much for sharing this.
I would really like to be able to use this too and run it on a Linux box.
Are the file locations important? Sadly I'm not a programmer but would it be possible for the code to create the required files if they are present ?
Could this script also be used to identify if any remote vpn users are connected?
Posted: Tuesday 15 August 2017 10:03
by vrmp
No problem!
It should work on Linux without any issue.
The files are created by the script, but the path where it does should be available.
On Windows the path /tmp is not available but on Linux it is (I'm using a Pi for my Domoticz installation)
I think it will also work for VPN users, but I did not test this.
When the VPN user is connected I think that account will be listed under clients?
If so you can use the name that is shown there or set an alias to the account.
You can use that name in the lua code to get the status.
Posted: Tuesday 15 August 2017 10:31
by JimmyH1969
Yes, it works. I had to modify it like this
curl --cookie-jar unifi_cookie_lua --insecure -H "Content-Type: application/json" -X POST -d "{\\"password\\":\\"Admin\\",\\"username\\":\\"Admin\\"}" https://192.168.1.12:8443/api/login
Using dubble backslashes did the trick i guess!
Thanx for all the help! :D
