thank you.
With JSON no experience, but with help from
this page I've got it working. The joined string goes to the string variable.
function meld (melding,prio)
if (not prio) then print ('<font color="purple">test: E R R O R geen prio meegegeven') end
if debug==1 then print ('<font color="purple">test: '..melding) end
if prio~=99 then
commandArray[index]={['SendNotification']='test#'..melding..'#'..prio}
index = index + 1
function split(str, pat)
local t = {} -- NOTE: use {n = 0} in Lua-5.0
local fpat = "(.-)" .. pat
local last_end = 1
local s, e, cap = str:find(fpat, 1)
while s do
if s ~= 1 or cap ~= "" then
table.insert(t,cap)
last_end = e+1
s, e, cap = str:find(fpat, last_end)
if last_end <= #str then
cap = str:sub(last_end)
table.insert(t, cap)
return t
l = { -- timeout for each device, in seconde.
'PIR_woonkamer', 172800, 1, -- 2 dagen
'PIR badkamer',172800, 2 -- 2 dagen
debug=1
meld ('starttest',99)
i=1
meld ('the original elements:',99)
meld ('**********************',99)
while l[i] do
meld (i..':'..l[i]..'/'..l[i+1]..'/'..l[i+2],99)
i = i + 3
s=table.concat(l, ";")
meld ('the joined string:',99)
meld (s,99)
l=split (s,';')
i=1
meld ('the join+split elements:',99)
while l[i] do
i = i + 3
Result:
2017-07-25 00:07:23.806 LUA: test: starttest
2017-07-25 00:07:23.806 LUA: test: the original elements:
2017-07-25 00:07:23.807 LUA: test: **********************
2017-07-25 00:07:23.807 LUA: test: 1:PIR_woonkamer/172800/1
2017-07-25 00:07:23.807 LUA: test: 4:PIR badkamer/172800/2
2017-07-25 00:07:23.808 LUA: test: the joined string:
2017-07-25 00:07:23.808 LUA: test: **********************
2017-07-25 00:07:23.809 LUA: test: PIR_woonkamer;172800;1;PIR badkamer;172800;2
2017-07-25 00:07:23.810 LUA: test: the join+split elements:
2017-07-25 00:07:23.810 LUA: test: **********************
2017-07-25 00:07:23.810 LUA: test: 1:PIR_woonkamer/172800/1
2017-07-25 00:07:23.810 LUA: test: 4:PIR badkamer/172800/2
