dzVentz Alarm Script starts here..
Posted: Saturday 22 July 2017 8:06
by remb0
I have Several virtual switches, some scripts and blockies to create an alarm.
The problem is that normal lua scripts and blocks are quite long and not easy to read.
I think with the options of dzVentz we can create a flexible alarm script that is easy to adopt for everyone.
Features:
- - Send notifications (silent alarm)
- Sounds siren for intruders
- Set alarm only when every door and windows are closed.
- Audio feedback through speakers
- Auto alarm (when everyone is away, and the vsSwitch: AutoAlarm=On set alarm armed after 20 min
- Saving option: If alarm is ‘armed away’ some or all light must off
Goals:
- - flexible and easy to read/control.
- less code / virtual devices / uservariables as possible (The key of dzVentz)
- good documentation (in script, and wiki with visio diagrams)
I Have some Visio schemas but they are based on my current scripts (from the wiki) and there is a lot of Dutch in it. So I want to start collecting Ideas, information, Icons, samples, scenarios etc. for starting over. Please reply with questions or ideas you have.
Start situation:
I will start simple with this:
set alarm though zipato keypad or internal domoticz panel (they must in sync)
speaker told me if there are door* open otherwise alarm will armed after 30 sec.
when alarm is armed:
and a door will opened speaker told you that you get 60 seconds to disarm the alarm
after 60 seconds notifications will send (if silent alarm mode is on (handy during testing) or the siren wil go off for 5 x 1 min
when disarming the alarm:
speaker will welcome you
all virtual switches will be resetted.
all devices for alarm will in 1 room plan, this is handy during testing.
Re: dzVentz Alarm Script starte here..
Posted: Saturday 22 July 2017 9:34
by heggink
Interesting. I started the original wiki and, as if yesterday have begun completely rewriting my alarm system due to dzvents being much more flexible. One objective was to reduce all the dummy devices that were needed before, the other is to reduce current complexity. Unfortunately I did find some unexpected behaviour in dzvents (armaway function switches domoticz.security straight to 'armed away' instead of after the timer) and, until that is resolved, still need a dummy.
Posted: Saturday 22 July 2017 12:51
by dannybloe
But is that a domoticz issue or dzvents? I can't test it myself right now.
Posted: Saturday 22 July 2017 14:34
by heggink
Good question. It's different from the original lua behaviour. It would be helpful to have a state between disarmed and armed called arming.
Posted: Saturday 22 July 2017 14:50
by dannybloe
Ah. I see it. I haven't enabled the timed support for those commands. That's an easy fix. I'll fix it after the weekend.
Re: dzVentz Alarm Script starts here..
Posted: Saturday 22 July 2017 16:03
by heggink
Watch it: I found that arming DOES use the built-in timer but whilst it is between disarmed and armed away, it already sets domoticz.security to armed away even though its not armed yet. The downside is that you cannot check against that to raise a PIR based alarm. That's where an interim state ("arming") would be very helpful.
Posted: Tuesday 25 July 2017 11:27
by dannybloe
Ok, but that is not a dzVents issue but a Domoticz issue. Perhaps file a request for this.
For now I'll make the timed options available for the security commands.
Posted: Saturday 29 July 2017 21:55
by remb0
heggink and I are worked on a new script but because his work is more next level (with doorlocks and auto arming) I started to make something as simple as possible (as start point) I want to post it here and get some feedback.
also a big thanks to dannybloe for his work and comments.
requirements:
2 user variables:
- AlarmSirenTime, integer (example: 3)
AlarmOnDelay, integer (example: 60)
3 virtual switches:
- vsAlarm_dooropen
vsAlarm_SoundSiren
vsAlarm_Detected
test door switch (testdeur) to test script without walking to the door everytime.
these switches have I placed in a roomplan: Alarm. handy to test. when script is finished I will place $ in front of the name.
2 dzVents scripts:
global_data
local SECURITY_PANEL = 'Security Panel'
local ALARM_DETECTED = 'vsAlarm_Detected'
local ALARM_DOOR_OPEN = 'vsAlarm_dooropen'
local SIREN = 'vsAlarm_SoundSiren'
local delay = 60
helpers = {
PlaySound = function(msg)
os.execute("sudo killall mplayer")
os.execute("sh /home/pi/domoticz/scripts/bash/Play_sound.sh '" .. msg .. "' ")
end,
alarmOn = function(dz, notify, delay)
dz.log('In alarmOn: ' .. dz.security, dz.LOG_DEBUG)
if (dz.security == dz.SECURITY_DISARMED) then
if (dz.devices(ALARM_DOOR_OPEN).state == 'Off') then
dz.log('Arming domoticz', dz.LOG_INFO)
--domoticz.devices('AlarmActive').switchOn() -- we will use this later as override
dz.devices(SECURITY_PANEL).armAway().afterSec(delay)
if (notify) then -- DB: use param notify
dz.notify('SECURITY', 'Arming Alarm', dz.PRIORITY_HIGH)
--dz.devices('Home Temp').updateSetPoint(15)
--dz.devices('Thermostat Downstairs Away').switchOn()
dz.helpers.playSound('Alarm Geactiveerd')
dz.log('Failed Arming domoticz, door/window still open', dz.LOG_ERROR)
if (notify) then
dz.notify('SECURITY', 'FAILED Arming Alarm, door/window open', dz.PRIORITY_HIGH) -- DB: const
dz.helpers.playSound('Alarm niet geactiveerd, er staat nog iets open') -- DB: camelCase
end,
alarmOff = function(dz)
dz.log('In alarmOff: ' .. dz.security, dz.LOG_DEBUG)
if (dz.security == dz.SECURITY_ARMED_AWAY) then
-- Reset al states
dz.devices(SIREN).switchOff()
dz.devices(ALARM_DOOR_OPEN).switchOff()
dz.devices(ALARM_DETECTED).switchOff()
--dz.devices('$AlarmActive').switchOff()
dz.devices('Sirene').switchOff() -- real siren!!
dz.devices(SECURITY_PANEL).disarm()
dz.log('Disarming domoticz', dz.LOG_INFO) -- DB: info?
if (notify) then
dz.notify('SECURITY', 'Disarming Alarm', dz.PRIORITY_HIGH)
dz.helpers.playSound('Alarm Uitgeschakeld')
AlarmScript
local CUSTOM_KEYPAD = 'Keypad Access Control'
local DELAY = 60 --seconds
local TEST_DOOR = 'deurtest'
local NOTIFY_ALARM = true
active = true,
devices = {
CUSTOM_KEYPAD,
'deur*', 'Schuifpui',
ALARM_DETECTED, ALARM_DOOR_OPEN, SIREN
logging = {
level = domoticz.LOG_DEBUG,
marker = "Alarm script: " -- prefix added to every log message
-- actual event code
execute = function(dz, dv)
local devices = dz.devices
local delay = dz.variables(DELAY).value
--CUSTOM_KEYPAD
if (dv.name == CUSTOM_KEYPAD) then
dz.log('Status bericht: ' .. dv.name .. dv.state, dz.LOG_DEBUG) -- DB: moeten er geen spaties oid tussen name en state? add loglevel, debug of info?
if (dv.state == 'On') then
if (dz.security == dz.SECURITY_DISARMED) then -- DB: gebruik dz constants
dz.log('CUSTOM_KEYPAD switches alarm ON')
dz.helpers.alarmOn(dz, NOTIFY_ALARM, delay) --DB: geef NOTIFY_ALARM ook mee, denk dat je hier je delay wil meegeven
if (dz.security == dz.SECURITY_ARMED_AWAY) then -- DB: constatns
dz.log('CUSTOM_KEYPAD switches alarm OFF', dz.LOG_INFO) --DB: loglevel?
dz.helpers.alarmOff(dz, NOTIFY_ALARM, delay) -- DB: NOTIFY_ALARM meegeven
return
-- Notify that alarm is triggered and siren will go off
if (dv.name == ALARM_DETECTED
and dv.state == 'On'
and dz.security == dz.SECURITY_ARMEDAWAY) then
dz.log('Alarm detected during Armed Away status, report it!')
dz.notify('SECURITY', 'ALARM: Sensor ging af', dz.PRIORITY_EMERGENCY)
if (NOTIFY_ALARM) then
local notifySub = '[ALARM] ' .. dv.name .. ' - device triggered'
local notifyMsg = '[ALARM] ' .. dv.name .. ' - ' .. dv.state .. ' - device triggered'
--DB: wel een lange subject.. zou je die niet korter houden en meer in het bericht stoppen?
dz.notify(notifySub, notifyMsg, dz.PRIORITY_EMERGENCY)
dz.log(notifyMsg, dz.LOG_DEBUG) --DB: dit is debug info lijkt me? dus debug level gebruiken?
devices(ALARM_DETECTED).switchOff().afterSec(20)
devices(SIREN).switchOn().afterSec(90)
dz.helpers.PlaySound('Beweging gedetecteerd, alarm gaat over 90 seconden af.', NOTIFY_ALARM)
dz.notify('SECURITY', 'Switching Siren on in 90 seconds', dz.PRIORITY_EMERGENCY)
return
-- Siren make somenoise!
if (dv.name == SIREN
-- devices('Siren').switchOn().forMin(duration)
dz.helpers.PlaySound('Herrie, wordt vervangen door werkelijke sirene!!!', NOTIFY_ALARM)
dz.notify('ALARM!!!', 'Siren switched on due to Alarm going off', dz.PRIORITY_EMERGENCY)
return
-- This point in script it will always be a door..
if (dv.name == TEST_DOOR) then
-- Motion detected
if (dv.bState) then
--local message -- DB: deze gebruik je alleen in de forEach dus dan kan je die daar ook declaren
-- first filter on name starting with Door/window
devices().filter(function(device)
local name = device.name
return (string.sub(name, 1, 4) == 'deur')
end).forEach(function(sensor)
local message = 'DSWStatus: ' .. 'Device ' .. sensor.name .. ' has status (' .. sensor.state .. '), '
dz.log(message, dz.LOG_DEBUG)
if (sensor.bState) then
-- if something is open but alarm is not armed vsAlarm_dooropen will switched because the alarm can't be activated
devices(ALARM_DOOR_OPEN).switchOn()
if (dz.security == dz.SECURITY_ARMEDAWAY) then
devices(ALARM_DETECTED).switchOn()
end)
sh script for voice speech on
#!/bin/sh
killall mplayer
izsynth -e google -v nl "$1"
please shoot! reply/pm with ideas, faults typos whatever you like.
Posted: Wednesday 08 August 2018 15:39
by swilting
Hi, is it possible to ad some shutters to this script, something like: if alarm is armed close shutter1 ?
And instead of alarm on / off I would like four states, full off /ground floor doors only / ground floor and doors / full on
Is this possible?
Thanx in advance
Posted: Saturday 22 December 2018 20:45
by Robert
swilting wrote:Hi, is it possible to ad some shutters to this script, something like: if alarm is armed close shutter1 ?
Is this possible?
Thanx in advance
Be aware that opening shutters would be a better option in case of escaping. Same for fire alarms. Make escape route free of obstacles. When burglar alarm is activated, they are already in your house. If you wanna leave your house to avoid a meet and greet, open everything
Posted: Friday 04 January 2019 11:22
by swilting
Robert,
That is a good option indeed,but my question was, "when I switch the alarm on, then automatically close the shutters, not when the alarm is triggerd
that would be to late
Reading more about programming this should be possible
Posted: Friday 04 January 2019 15:27
by waaren
swilting wrote: Friday 04 January 2019 11:22
Robert,
I would not combine code triggered by setting the alarm states with code that is supposed to do stuff based on an actual alarm. These are quite different type of events.
Example of script reacting to security state change below
-- secTrigger
security = { domoticz.SECURITY_ARMEDAWAY,
domoticz.SECURITY_ARMEDHOME,
domoticz.SECURITY_DISARMED },
execute = function(dz,item)
local shutter = dz.devices(nnn) -- change nnn to ID of your shutterDevice
dz.log("Event has been triggered by securityPanel. State is now: " .. item.trigger,dz.LOG_FORCE)
if item.trigger == dz.SECURITY_ARMEDAWAY or item.trigger == dz.SECURITY_ARMEDHOME then
shutter.close()
-- add more actions here when needed on ARMED*
else -- Disarmed
-- actions needed on DISARMED here
Posted: Thursday 06 February 2020 19:35
by Opus
Has anybody this idea completed? Sitting here over my old LUA script an find no way for nice working.
Posted: Thursday 06 February 2020 20:07
by dressie
heggink wrote:Interesting. I started the original wiki and, as if yesterday have begun completely rewriting my alarm system due to dzvents being much more flexible. One objective was to reduce all the dummy devices that were needed before, the other is to reduce current complexity. Unfortunately I did find some unexpected behaviour in dzvents (armaway function switches domoticz.security straight to 'armed away' instead of after the timer) and, until that is resolved, still need a dummy.
Let me know when it's done. I'm still using the old dzvents "ideAlarm", but since the developer left it hasn't been updated or worked on.
I'm curious about a new one.
Verstuurd vanaf mijn SM-G970F met Tapatalk
