Rfxcom stops working
Posted: Thursday 20 July 2017 6:00
I have a Domoticz configuration (v3.5877) on Rasp 2 with a RFXCom433 attached(firmware version Ext/1006). It has worked fine for a while with a few temp sensors (Viking) and Nexa switches. Occasionally I miss temperature readings from one sensor due to bad coverage, but I can live with that.
However the last few days RFXCom I have run into problems. Rfxcom stops. Or at least no temp data is received and I can't control any Nexa switch either. The log does not give any info. No lines labeled Rfxcom. Sometimes I can get things working again by re-enabling the Rfxcom HW device on the HW tab. Doing so I can see in the log how the Rfxcom module is initiated and temp readings start to come in. However, yesterday RFXcom stopped again, and this time re-enabling the HW module didn't help either. Nothing showed up in the log, but after reboot everything is fine again.
