Milight gateway running on ESP8266
Mooseknuckle
Post by Mooseknuckle »
Hi guys,
In search for a good solution for my Milights I found this neat project:
https://github.com/sidoh/esp8266_milight_hub
Just installed it because I had the parts lying around and it works like a charm. You can make a lot of virtual gateways and add them all to Domoticz so no more 4 zone limit. You even can spoof a gateway if you already have one. By far the cheapest solution with lots of possibilities:
- no zone limit
- rest api
- MQTT integration
- UDP gateway
Greetings,
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
sincze
Domoticz version: 2024.4
Re: Milight gateway running on ESP8266
Post by sincze »
Nice, find :D
I've these parts somewhere as well, let me give it a try :lol:
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
ledfreak3d
Domoticz version: 3.8025
Post by ledfreak3d »
found this one some time ago also have it running for a couple of months now works beter then the original milight gw
Unleashe the magic smoke ;)
JoshDinsdale
Post by JoshDinsdale »
Anyone had any luck using CCT bulbs with this? I can pair them to the ESP and control them via its web interface, but domotics doesnt seem to be sending the right commands. I've tried using all of the different bulb variants and changing the controller version between 5 and 6 but nothing works.
hayman
Domoticz version: 3.8153
Post by hayman »
JoshDinsdale wrote: Wednesday 11 October 2017 18:18 Anyone had any luck using CCT bulbs with this? I can pair them to the ESP and control them via its web interface, but domotics doesnt seem to be sending the right commands. I've tried using all of the different bulb variants and changing the controller version between 5 and 6 but nothing works.
Same as above any help please
hayman
Post by hayman »
sincze wrote: Wednesday 19 July 2017 20:39 Nice, find :D
thanks know i get it link to Domoticz
sincze
Post by sincze »
Excellent, well done!
This forum is all about sharing knowledge. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
poudenes
Domoticz version: 3.8993
Post by poudenes »
I can sniffer my bulbs and can add them. But When i want try to pair the bulb nothing happen. No flashing of bulb.
And how can i add unlimited zones. I see 4 groups and a "all" ?
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
Someone get this working with a FUT 18 milight bulb ?
Sent from my ONEPLUS A6003 using Tapatalk
It's nice to be important, but it's more important to be nice
Scooter ;)
