Time out with Remotec ZXT-120
Posted: Saturday 15 July 2017 16:37
I did buy a Remotec zxt-120 to work with my chigo airco. I use code 42, that works fine. Only I have the problem that the node seems to be online, but when I send a command, I get a time out as result. Sometimes it works, but more negative as positive. At the tab hardware, at the z-wave nodes. The node is online and not in sleep. I think something goes wrong in domoticz with this node.
2017-07-15 14:25:18.367 User:[email protected] initiated a Thermostat Mode command
2017-07-15 14:25:28.396 OpenZWave: Received timeout notification from HomeID: 3649772819, NodeID: 30 (0x1e)
I do the power supply not with battery's, but with Usb. I did change the mode to "always listening mode" Does any one has an idea ?
Greetings,
Peter
Greetings,
Peter
