Help with script to Control solar water heater
BasSpiek
Post by BasSpiek »
Hello, can anyone help me please? :D
I would like to control a solar water heater with domoticz.
With blocky I do not get that, so I think I need a script here.
I have 2 onewire temperature sensors 1 in the collector and 1 in the boiler and a pump switch.
If the temperature difference is greater than 10 degrees, the pump must go on and if the temperature difference is smaller than 3 degrees, the pump must be switched off.
If the temperature in the collector is higher than 140 degrees, the pump must also be switched off.
Thanks in advance for your help!!
Greetings Bas
BasSpiek
Re: Help with script to Control solar water heater
Post by BasSpiek »
domoticz zonneboiler.jpg (41.47 KiB) Viewed 2001 times
My sensors en pump in domoticz
BasSpiek
Post by BasSpiek »
Nobody how can help me?
underscore4
Post by underscore4 »
Would you please post your LUA blocky example?
some question, which one would be the nominal temperature?
BasSpiek
Post by BasSpiek »
Thx for your reaction,
I dont have the blocky anymore, and what do you mean with nominal temperature?
thx
BasSpiek
Post by BasSpiek »
i have made a quick overview,
BasSpiek
Post by BasSpiek »
Can anybody help me with this please? thx
