Dimmer controlable with wallswitch
Posted: Wednesday 12 July 2017 11:07
I need you're advice/tips on a dimmer configuration.
Our house has some rotary switches on the wall from Gira (the regular on/off swithes/outlets/dimmers etc.) to control some dimmers.
The dimmers are wallmounted behind the rotary switches as a normal 'not-automated' installation.
What we would like is to replace this configuration with a wireless dimmer working on 433Mhz, controlable through RF-Link, or WiFi/ESPEasy based to dim the lights with Domoticz.
However the wallswitch should work as well to control/dim the lights. The rotary switch would be perfect to re-use, but a pulse-switch is also an option (Gira has these pulse-switches as well).
I have seen the KAKU dimmers which work on existing wallswitches, but as I read from the manual they are not controlable with the wallswitch other then on/off at 100%/0%.
Any ideas on what materials/brands to use? Thanks
