python error 32512
Posted: Tuesday 11 July 2017 22:58
hi guys
anyone able to shed some light on this python code for me?
i can run the code with sudo or without and it works
but in domoticz i get a error
2017-07-12 06:50:39.716 Executing script: /home/pi/domoticz/scripts/python/wemo_off.py
2017-07-12 06:50:39.726 Error: Error executing script command (/home/pi/domoticz/scripts/python/wemo_off.py). returned: 32512
i have chmod the file to 777
is there something inside domoticz ive missed for permissions?
as i said it works perfectly in console with or without root so im unsure whats now blocking it
#!/usr/bin/python
import re
import urllib2
# Configuration:
# Enter the local IP address of your WeMo in the parentheses of the ip variable below.
# You may have to check your router to see what local IP is assigned to the WeMo.
# It is recommended that you assign a static local IP to the WeMo to ensure the WeMo is always at that address.
# Uncomment one of the triggers at the end of this script.
ip = '10.0.0.3'
class wemo:
OFF_STATE = '0'
ON_STATES = ['1', '8']
ip = None
ports = [49153, 49152, 49154, 49151, 49155]
def __init__(self, switch_ip):
self.ip = switch_ip
def toggle(self):
status = self.status()
if status in self.ON_STATES:
result = self.off()
result = 'WeMo is now off.'
elif status == self.OFF_STATE:
result = self.on()
result = 'WeMo is now on.'
else:
raise Exception("UnexpectedStatusResponse")
return result
def on(self):
return self._send('Set', 'BinaryState', 1)
def off(self):
return self._send('Set', 'BinaryState', 0)
def status(self):
return self._send('Get', 'BinaryState')
def name(self):
return self._send('Get', 'FriendlyName')
def signal(self):
return self._send('Get', 'SignalStrength')
def _get_header_xml(self, method, obj):
method = method + obj
return '"urn:Belkin:service:basicevent:1#%s"' % method
def _get_body_xml(self, method, obj, value=0):
return '<u:%s xmlns:u="urn:Belkin:service:basicevent:1"><%s>%s</%s></u:%s>' % (method, obj, value, obj, method)
def _send(self, method, obj, value=None):
body_xml = self._get_body_xml(method, obj, value)
header_xml = self._get_header_xml(method, obj)
for port in self.ports:
result = self._try_send(self.ip, port, body_xml, header_xml, obj)
if result is not None:
self.ports = [port]
return result
raise Exception("TimeoutOnAllPorts")
def _try_send(self, ip, port, body, header, data):
try:
request = urllib2.Request('http://%s:%s/upnp/control/basicevent1' % (ip, port))
request.add_header('Content-type', 'text/xml; charset="utf-8"')
request.add_header('SOAPACTION', header)
request_body = '<?xml version="1.0" encoding="utf-8"?>'
request_body += '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">'
request_body += '<s:Body>%s</s:Body></s:Envelope>' % body
request.add_data(request_body)
result = urllib2.urlopen(request, timeout=3)
return self._extract(result.read(), data)
except Exception as e:
print str(e)
return None
def _extract(self, response, name):
exp = '<%s>(.*?)<\/%s>' % (name, name)
g = re.search(exp, response)
if g:
return g.group(1)
return response
def output(message):
print message
switch = wemo(ip)
# Configuration:
# Uncomment only one of the lines below to make the script work.
#output(switch.on())
output(switch.off())
#output(switch.toggle())
#output(switch.status())
