MyDomoticz won't connect
Posted: Tuesday 11 July 2017 21:02
by AndrePower
Instructions on the wiki
https://www.domoticz.com/wiki/MyDomoticz are a bit unclear to me, but I managed to register for my.domoticz.com.
I obtained the API key and filled this and the my.domoticz.com password on my local Domoticz running on Rpi3.
Then, when clicking on Save Settings the dashboard is shown very quickly, despite the fact that the wiki states that "instance will automatically try to connect to the MyDomoticz service.". The Instance ID stays "(none)"
It seems no connection attempt is made. The MyDomoticz page shows "Enter your api data to your own Domoticz in order to use this service".
In the log some errors are present
2017-07-11 20:25:39.695 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
What can I do to investigate and resolve this issue?
Re: MyDomoticz won't connect
Posted: Wednesday 12 July 2017 9:11
by AndrePower
I'm thinking of port forwarding on my router (already opened 8080, 443, 6000 and 6010 all TCP) and the host firewall.
Any ideas what ports need to be open in order to receive requests from MyDomoticz?
Posted: Thursday 13 July 2017 12:22
by pandy
Hi "AndrePower",
I have the same problem
..I tried to reinstall both the operating system (jessie lite) on my raspberry model b and domoticz but has not changed anything..
Have you resolved in the meantime?
thank you
Luca
p.s. I'm sorry for my english
Posted: Saturday 15 July 2017 20:58
by AndrePower
Hi Luca,
No I'm sorry, I'm still trying to figure it out.
I have no idea what is supposed to happen. I don't know whether it is My.Domoticz.com which is trying (should try) to contact my local Domoticz or the other way around. Therefore, I also don't know which port to forward and/or open in the firewall.
Posted: Monday 17 July 2017 13:18
by autopete
I also can't get my local instance running on Raspberry Pi to connect to MyDomoticz. It used to work but returning to it last week shows a last seen timestamp of a year ago.
When I restart my Raspberry Pi I also see Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative) but I'm not sure how significant it is.
Is it working for others at the moment? Anyone got any troubleshooting tips?
Posted: Monday 17 July 2017 13:20
by skutudden
Hi!
I had the same problem early this year. Then I went for the beta versions of Domoticz and then it worked. Not sure if that was a good solution or not but I am still running the beta versions and it works fine for me.
/Björn
Posted: Monday 17 July 2017 19:50
by autopete
Nice one!
I just updated to the beta and my instance appears again in MyDomoticz.
Thanks Pete
Posted: Tuesday 18 July 2017 10:26
by pandy
I just updated to the beta and the instance appears in Domoticz
but When I try to log in Mydomoticz login web page from the internet, the message appears
"Dashboard - Enter your api data to your own Domoticz in order to use this service" .... and even compile all fields does not appear in the domoticz login screen
Does anyone have any idea how to solve it?
thank you
Posted: Tuesday 18 July 2017 14:58
by autopete
I can't help with that but can report that although my instance appeared in MyDomoticz with my RFXCom / Pi and 15 or so LightwaveRF devices the beta was unreliable and frequently unresponsive. Could have been something specific to my system but I had to go back to the stable version and give up on MyDomoticz for the moment.
Posted: Thursday 24 August 2017 19:44
by cribben
I managed to register MyDomoticz with API-key and password the Instance ID was assigned. Then I made a mistake , I tried to change the name "My Domoticz" to a more descriptive name. After that the instance disappeared from MyDomoticz screen, only the text "Dashboard" is shown.
Is it possible to reset and restart the registration process or what can I do???
/cribben
Posted: Tuesday 24 November 2020 0:37
by MCR777
This is an old thread, but I have exactly the same problem. Created MyDomoticz account and added the API-key to local Domoticz settings page. MyInstanceId says (none). I have tried to delete account and create new one. Restarted local instance but the new API-key is still not working. What am I doing wrong? Hope someone can help. Thanks in advance!
Posted: Tuesday 24 November 2020 11:41
by wkossen
I can't get it to work either. so hopefully someone will post solutions.
