Code HTML5 / ICONS / DESIGN
Posted: Friday 07 July 2017 16:26
I'm not sure of or leave my message, thanks moderators to put it in the right sections ...
I'm webdesigner and I would like to create a custom template, and I realize that the generated code does not separate the content from the form, many html tags contain styles and overloading with a new style (in folder) has only limited action, because many elements are in preloaded css
I would like to contribute to the improvement of DomoticZ which in my opinion is an excellent solution for home automation.
Would it be possible for a team to generate HTML5 compliant code to simplify the creation of new design?
Would there also be the possibility to propose a naming of icons more standardized and to migrate it in svg rather than in png, in order to make their evolution more flexible?
Note : for this last point I have in part created icons visiblent here: viewtopic.php?f=8&t=7749
And that they are all in the form of vectors ...
Thank you
Thank you
