Alert tab
Posted: Sunday 25 June 2017 18:29
I'm using several window sensors, a garage senosor and so on. When leaving my house, I set security to on. When doing this, I check via script, if every window is closed. If one ore more is open, I get a notification. Then I have to look, which one is open. It would be very nice, if I could show the open window devices in a special tab. So if one window is opended, the device is placed in this tab, if it is closed, it will be removed from the tab. All would happen via script. The advantage would be, that I could see all problem devices in one view. I thought about defining a room unsecure, but I think it is not possible, to change the room information of a device via script. Has anybody a idea how to handle this. Thanks.
