SSH into a Synology NAS using a key
Posted: Friday 23 June 2017 15:13
After several researches on Google, I try to connect through ssh from my Raspberry (with Domoticz) to my Synology NAS with a key to log without entering a password.
What I've done unitl now allow me to connect from Putty to my NAS without password (with key created thanks to Puttygen) -> Thus, I conclude that on NAS side, everything is correctly configured.
However when I try to connect to my NAS from my Raspberry through ssh, it still ask me the password, as you can see below :
Do you know what I can do to resolve this problem please ?
If you need more log or information, I will give it.
Thanks in advance for your help.
Baptiste
pi@raspberrypi:~ $ ssh -p 52 [email protected] -vvv
OpenSSH_6.7p1 Raspbian-5+deb8u3, OpenSSL 1.0.1t 3 May 2016
debug1: Reading configuration data /home/pi/.ssh/config
debug1: /home/pi/.ssh/config line 1: Applying options for 192.168.1.11
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.1.11 [192.168.1.11] port 52.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: identity file /home/pi/.ssh/nas_priv_key type -1
debug1: identity file /home/pi/.ssh/nas_priv_key-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.7p1 Raspbian-5+deb8u3
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.8p1-hpn14 v6
debug1: match: OpenSSH_6.8p1-hpn14v6 pat OpenSSH* compat 0x04000000
debug2: fd 3 setting O_NONBLOCK
debug3: put_host_port: [192.168.1.11]:52
debug3: load_hostkeys: loading entries for host "[192.168.1.11]:52" from file "/ home/pi/.ssh/known_hosts"
debug3: load_hostkeys: found key type ECDSA in file /home/pi/.ssh/known_hosts:2
debug3: load_hostkeys: loaded 1 keys
debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@open ssh.com,[email protected],ecdsa-sha2-nistp521-cert-v01@op enssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: [email protected],ecdh-sha2-nistp256,ecdh- sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hel lman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: [email protected],ecdsa-sha2-n [email protected],[email protected],ecdsa-sha2 -nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,[email protected] om,[email protected],[email protected],ssh-rsa-cert-v00@op enssh.com,[email protected],ssh-ed25519,ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,[email protected] om,[email protected],[email protected],arcfour256,arcfour128,ae s128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndae [email protected]
debug2: kex_parse_kexinit: [email protected],[email protected],hmac [email protected],[email protected],[email protected] m,[email protected],[email protected],hmac-sha2-256,hmac-sha2-512,hmac-sha1 ,[email protected],[email protected],hmac-sha1-96-etm@openss h.com,[email protected],hmac-md5,hmac-ripemd160,hmac-ripemd160@openssh .com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,[email protected],zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256,ssh-ed25519
debug2: kex_parse_kexinit: aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc
debug2: mac_setup: setup [email protected]
debug1: kex: server->client aes128-cbc [email protected] none
debug1: kex: client->server aes128-cbc [email protected] none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA 2f:5a:34:b1:2e:c4:d1:7e:1f:cc:81:b2:08:b6:59:25
debug1: Host '[192.168.1.11]:52' is known and matches the ECDSA host key.
debug1: Found key in /home/pi/.ssh/known_hosts:2
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/pi/.ssh/nas_priv_key ((nil)), explicit
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /home/pi/.ssh/nas_priv_key
debug3: sign_and_send_pubkey: RSA 3f:58:d3:03:7f:09:32:35:00:21:8e:87:51:34:38:a6
debug2: we sent a publickey packet, wait for reply
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
[email protected]'s password:If you need more log or information, I will give it.
Baptiste
