Turn Light On
Posted: Wednesday 21 June 2017 11:50
by Padster
I have a number of 'Light' devices. I can turn the light on and off manually by clicking the 'bulb' icon on the device. However if I am creating a Blockly script and use the 'Logic' 'Set' statement to set the device to 'On' it won't turn the light on. If I create a scene or group with the light device I can turn it on using the scene/group set statement.
Am I supposed to be able to turn a light on using the Logic 'Set' statement? If yes any idea why its not working?
Re: Turn Light On
Posted: Wednesday 21 June 2017 11:55
by StanHD
Should work, here is an example that works:-
Can you show your Blockly?
Re: Turn Light On
Posted: Wednesday 21 June 2017 12:06
by Padster
Here is the test Blockly - very simple
Here are the current states
The lamp stays off.
My Domoticz info is;
Version: 3.5877
Build Hash: 15b013c
Compile Date: 2016-11-10 15:44:33
Re: Turn Light On
Posted: Wednesday 21 June 2017 12:55
by tommit01
Hi, please
try to use 'On' tile from blockly category 'Logic' instead of string tile and test it again....
P.S.:
I still don't know why this is still called Blocky ... in so many posts ..it is 'Blockly'
BR
Tommit
Re: Turn Light On
Posted: Wednesday 21 June 2017 13:00
by heggink
Indeed. Unlike lua, switch devices need a state, not a string indicating the state.
Re: Turn Light On
Posted: Wednesday 21 June 2017 13:04
by Padster
Yep - thanks guys that sorted it.
Re: Turn Light On
Posted: Wednesday 21 June 2017 13:12
by Hobbybob
tommit01 wrote:Hi, please
P.S.:
Hahaha, even this forum is called Blocky. I've always thought it was Blocky, never noticed the additional L
Re: Turn Light On
Posted: Wednesday 21 June 2017 13:21
by Padster
Hi Guys,
A couple of follow up questions.
Although the Blockly below works - should I be using the switch states rather than a string?
Also in StanHD's post in this thread his 'and' condition allows for two lines thus making the test format neater. I can only see an inline 'and' condition. How can I format my Blockly's like StanHD?
Re: Turn Light On
Posted: Wednesday 21 June 2017 13:58
by StanHD
Right Click on the "And" block, then select "External Inputs" ;)
Re: Turn Light On
Posted: Wednesday 21 June 2017 14:02
by Padster
Many thanks - I didn't even know you could right click on the Blockly elements.
Re: Turn Light On
Posted: Wednesday 21 June 2017 14:03
by StanHD
See working Blockly below. No strings :)
Re: Turn Light On
Posted: Wednesday 21 June 2017 14:17
by Padster
See if I've got this right :)
It the LR PIR is on AND (LR Lights Auto=on AND LR Updown Light=off)
AND
Living Room < 100
SET Updown Lights Level= 5%
I need to learn Blockly better than I have.
Would this smoke/heat detection work?
Basically if any of the smoke or heat detectors are ON then Set Smoke_Alarm variable to 'On', turn the Alarm Lights On and send a notification.
Else
If all the Heat and smoke sensors are Off set the variable Smoke_Alarm to 'Off' after 6 mins
Re: Turn Light On
Posted: Wednesday 21 June 2017 15:48
by StanHD
Yes the interpretation of my Blockly is correct :)
Regarding your Blockly, it looks OK to me, however I always use numbers in user variables, but that's just me. Perhaps you could mock something up with some dummy switches to test?
Re: Turn Light On
Posted: Wednesday 21 June 2017 16:23
by Padster
Thanks again.
My Blockly did work when the 'AND' and 'OR' conditions were all inline. Just not sure is nesting them changed the interpretation. I know the order of evaluation is important.
I'll press the smoke alarm test when I get home.
