Monitor Security Panel for updates
Posted: Tuesday 20 June 2017 14:55
by dennusb
I would like to watch the Security Panel (buildin Domoticz thingy) for status changes. So i've tried :
if(devicechanged["Domoticz Security Panel"]) then
But that does not work. What code would i need to monitor it for status changes?
Re: Monitor Security Panel for updates
Posted: Tuesday 20 June 2017 14:59
by emme
I do not monitor the secpanel... but in my scripts I use to check global variable 'Security' instead of the device
ciao
M
Posted: Tuesday 20 June 2017 15:01
by dennusb
emme wrote:I do not monitor the secpanel... but in my scripts I use to check global variable 'Security' instead of the device
ciao
M
But do you monitor it for changes? Or do you just run if(globalvariable['Security'] == 'Armed Away') or something like that?
Posted: Sunday 25 June 2017 12:36
by Keleos
Hello everyone,
I'm asking me exactly the same because I'd like to use the fibaro wallplug as alarm indicator.
Greetings
Kel
Posted: Sunday 25 June 2017 12:44
by jvdz
Just create a LUA file called: script_security_panel-changes.lua
In there you can simply do something like:
printlog('###', 'SecPanel: status changed to ' .. globalvariables['Security'])
if globalvariables['Security'] == 'Disarmed' then
elseif globalvariables['Security'] == 'Armed Home' then
elseif globalvariables['Security'] == 'Armed Away' then
Jos
Posted: Sunday 25 June 2017 12:53
by Keleos
Hi Jos,
thank you very much, this works like a charm
My mistake was: I did not set the type to "
security" so only the disarm was recognized.
Have a nice Sunday
Kel
