Hi There.
I have a Somfy rts sunblind, all is ok with m'y rfxcom.
On Domoticz he got 3 buttons :
- open
- close
- stop
Using m'y RFLink i'm able to know if the Real remote is used and which ordre is send.
I want to use this ability to update the rfx devices. Not trigger but really update using commandarray['updatedevice'] command.
I found that value can be 0 or 1 but this value never update the device to "open".
Is There another secret value or do I need to use the Json api?
Update devices rfy devices status
deennoo
http://domo-attitude.fr
zicht
- Domoticz version: 2023.1+
Re: Update devices rfy devices status
Have a look here, had simmilar questions before :
http://www.domoticz.com/forum/viewtopic ... 65#p137111
The only thing that does not work is receiving the original remote... so worked around that.
Hope it helps to understand better
deennoo
Rfx will never listen about Real remote, éven a Somfy tahoma didn't listen about rts remote.zicht wrote:Hi
Only RFLink or rfp1000 Can do this
Will check your code
lec668
- Domoticz version: 2021.1
@Deeno
Were you able to figure how to change the Somfy blinds status ? Here I'm trying to change it depending on a sensor.
I'm having the same trouble, RFY status change to 'stopped' whatever I put in the commandArray['UpdateDevice'] command, (tried On/Off Open/Closed...
if (devicechanged ['sensor_baie_bureau'] == "Open") then
print ("STORE BUREAU Open")
commandArray['UpdateDevice']='280|0|Off'
The command workds fine with another on/off light switch, but I've never beeen able to use it with a blind.
Regards !
Regards !
meal
- Domoticz version: 2025.2
Hello
I add the same functionality to setup.
You can use the following LUA function to update the RTS Blind based on the Status of the remote control.
function Visu_Blind_Status(Blind, Status)
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
iBlind=otherdevices_idx[Blind]
if Status=='On' then
value=18 -- Closed for Venetian EU Blind
elseif Status=='Off' then
value=17 -- Open for Venetian EU Blind
value=0 -- Stop
local url0 ="https://<<IP address>>/json.htm?type=command¶m=udevice&idx=" .. iBlind.. "&nvalue=" ..value.. "&svalue=0&parsetrigger=false"
local url ='curl -s "' .. url0 .. '"'
local handle = io.popen(url)
local result = handle:read("*a")
handle:close()
output = json:decode(result)
if output==nil then
return nil
if output.status~="OK" then
return nil
return true
Example of implementation:
Blind1, Blind2, Blind3 are the name of the Somfy Blinds
Remote Control1, Remote Control2,Remote Contro3 are the name of the remote controls
Status is Open , Stopped or Closed
local RemoteControlBlinds = {
["Remote Control1"]="Blind1",
["Remote Control2"]="Blind2",
["Remote Control3"]="Blind3",
function timedifference(timestamp)
y, m, d, H, M, S = timestamp:match("(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)")
difference = os.difftime(os.time(), os.time{year=y, month=m, day=d, hour=H, min=M, sec=S})
return difference
for RemoteControlBlind,Blind in pairs(RemoteControlBlinds) do
if (devicechanged[RemoteControlBlind]) then
s = otherdevices_lastupdate[RemoteControlBlind]
Status=otherdevices[RemoteControlBlind]
if timedifference(s) > 1 then -- to avoid successive state changes sent by the remote control
BR
value=0 -- Stop
handle:close()
if output==nil then
return nil
return nil
return true
return difference
BR
meal
lec668
Thanks, will have à look and convert it to "pure" lua / not JSON
Où avais-tu trouvé les valeurs 17 et 18 ?
Encore merci ! Thx
Encore merci ! Thx
meal
I found the values 17 and 18 In the source codes.
I would be interested in the LUA version when you get it.
BR
BR
meal
lec668
OK, I understand now, the "official" n & s values I took from the json documentation are not the ones I get
When manually testing with a http request I get
0 -> stopped
1 -> open
3 -> closed
So to reflect the real state of the blind, taken from my 'sensor_baie_bureau' here, it would change my script like this :
-- loop through all the changed devices
-- for deviceName,deviceValue in pairs(devicechanged) do
-- print ("Device based event fired on '"..deviceName.."', value '"..tostring(deviceValue).."'");
-- end
if (devicechanged ['sensor_baie_bureau'] == "Closed") then
print("STORE BUREAU en cours de fermeture")
print( otherdevices['STORE BUREAU'] )
commandArray['UpdateDevice'] = '280|3|0'
--commandArray[#commandArray+1] = {['UpdateDevice'] = '280|3|0' }
elseif (devicechanged ['sensor_baie_bureau'] == "Open") then
print("STORE BUREAU completement ouvert")
commandArray['UpdateDevice'] = '280|1|0'
--commandArray[#commandArray+1] = {['UpdateDevice'] = '280|1|0' }
elseif (devicechanged ['BOUTON2'] == "Click") then
print("Click BOUTON2")
--just show the state of the blind in log when I press a pushbutton
Thanks for pointing me in the right direction ! A charge de revanche
0 -> stopped
1 -> open
3 -> closed
-- end
