Idea how to automatically turn on the lights when it gets dark
LastSamurai
Post by LastSamurai »
Hi, I am using dzVents (great piece of software!) with my domoticz controller to control a set of MySensors devices. I have several RGBW lights in my bed room and a light sensors.
Currently I can only manually (or via an amazon echo) control these lights. As I am using them nearly every day once it gets dark (which is already before sunset!) I really want to automate this.
The idea would be to automatically turn on the lights based on a certain light level send from the sensor (even better version would be to do it in smaller steps). The problem though is that at a certain point I want to go to sleep and the lights have to stay off then. Any idea how to (logically) structure this so that I can create a script for this?
pvm
Domoticz version: 4.10538
Re: Idea how to automatically turn on the lights when it gets dark
Post by pvm »
One option could be to add a virtual switch 'lights -off' in a blockly statement. You can switch this when you go to sleep and switch it back when it is light again or at timer st 10.00.
freijn
Domoticz version: Stable
Post by freijn »
Not sure if you know this but:
I am using 10 min after sundown as a switch on. It adjusts perfectly during the summer.
Only disadvantage on a dark clouds day, it could be a few min earlier..
LastSamurai
Thanks for your help. For now I am using a virtual switch to indicate when the script should to its work.
dutchdevil83
Domoticz version: latest
Post by dutchdevil83 »
I use a virtual LUX sensor created with the Wunderground plugin. Then i wrote a script that looks at the outside light (when below 2000lux then) also look at te time (when it`s >16 hour) and look at a variable (when lightonceaday = 0) when all of this is true then turn on the lights (and make the uservariable lightonceaday = 1 (to prevent switching the light more then once a day). Don`t forget the reset this uservariable to 0 on 3 oclock in the midday or something like that.
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
EdwinK
Post by EdwinK »
Could you post the script? For the outside lamp I now use the 'on before sunset' and 'off at sunrise' in the device settings, but if it visibility gets low I want it to turn on as well.
(Im not a scripter, so if it involves heavy scripting, then I need to forget it)
Derik
Post by Derik »
mm perhaps wait untill dzevent is build in domoticz..
new version should be work better then the v1
dutchdevil83
EdKo66 wrote:Could you post the script? For the outside lamp I now use the 'on before sunset' and 'off at sunrise' in the device settings, but if it visibility gets low I want it to turn on as well.
Do you have already a outside lux sensor created from the "weather hardware" ? It involves some scripting skills and some trial and error to get things functioning the way you want sometimes but that`s way i learned it also :D
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
Misterik
Post by Misterik »
I am using the following blocky /lua-scripts:
To determine the lux value with the weatherunderground api https://www.domoticz.com/wiki/Real-time ... _sensor.... I am also working on a mysensor project to measure my own lux-value, because some rooms with no windows or just one window need light before rooms with a lot of windows.
The following to determine if it is already dark
is het donker.jpg (88.44 KiB) Viewed 6524 times
And another blocky to turn on lights. I currently looking into the feature to turn on the lights gradually
lampen aan.jpg (116.88 KiB) Viewed 6510 times
RPI-3 : RFLink + Zigbee2MQTT + Shelly + MySensors + Milight
dannybloe
Post by dannybloe »
Now, if someone creates a Blockly to dzVents converter, that would be awesome (and I don't think very hard to do).
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi There,
I have made a LUA script to do exactly what you want.
viewtopic.php?f=38&t=14237
good luck and have fun with it.
Jan
