Open zwave control panel empty Topic is solved
joneng
Post by joneng »
I can´t get my install of open zwave to work. I have domoticz on rpi with z-stick gen 5.
Something happened earlier but I don´t know what, because it worked to begin with for several months and I had zwave devises added.
When starting domoticz I get the following lines in the log related to openzwave:
2017-06-18 07:53:37.440 OpenZWave: Starting...
2017-06-18 07:53:37.440 OpenZWave: Version: 1.4-2228-gbce4a88-dirty
2017-06-18 07:53:37.440 OpenZWave: using config in: /home/pi/domoticz/Config/
2017-06-18 07:53:38.488 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
2017-06-18 07:53:39.498 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
2017-06-18 07:53:40.503 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
2017-06-18 07:53:41.507 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
2017-06-18 07:53:42.512 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
and
2017-06-18 07:57:03.824 Error: Webserver: File '/ozwcp/devpost.html': No such file or directory (2)
2017-06-18 07:57:05.042 Error: Webserver: File '/ozwcp/devpost.html': No such file or directory (2)
The control panel looks like this:
Screen Shot 2017-06-18 at 08.35.49.png (64.21 KiB) Viewed 8241 times
I have no idea on what to do to solve this - can someone help me?
regards Jonas
Domoticz on Rpi and MySensors - both amazing projects :-)
joneng
Re: Open zwave control panel empty
Post by joneng »
Is there for example a smart way to reinstall open zwave, so that everything is set back to default?
/Jonas
EddyG
Post by EddyG »
How did you install it?
The '/ozwcp/devpost.html' is missing from the domoticz install, at least I don't have it either in both production as beta.
blacksn0w
Post by blacksn0w »
Have you restarted your machine recently?
Had the same problem, the port of the z-wave stick have changed.
Not your devices are missing, your controller is not recognised at all.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Try this before opening OZWCP:
In domoticz goto settings -> hardware
select setup for your zwave controller
joneng
Post by joneng »
blacksn0w: You were so right - the usb port had changed! So simple! But now it works again,
thank you all for helping me out!
Regards Jonas
Andree
Post by Andree »
Hi to all, i have the same problem but in my case the port is not changed and, if I try to change (from 1 to 7), nothing happen.
I use Domoticz on Windows and i have update some version in the last year but this problem remain.
Can anyone help me?
dextm80
Domoticz version: 4.10159
Post by dextm80 »
hi guys, same problem, i follow this guide: https://www.domoticz.com/wiki/PersistentUSBDevices
all ok,add my device....... since i restart, and then this is the log:
 2018-01-16 16:11:09.940 Domoticz V3.8809 (c)2012-2018 GizMoCuz
2018-01-16 16:11:09.940 Build Hash: 4ec5e16, Date: 2018-01-15 13:01:28
2018-01-16 16:11:09.941 Startup Path: /xxx/xxx/domoticz/
2018-01-16 16:11:09.975 Sunrise: 07:47:00 SunSet: 17:24:00
2018-01-16 16:11:09.975 Day length: 09:37:00 Sun at south: 12:35:00
2018-01-16 16:11:09.975 Civil twilight start: 07:17:00 Civil twilight end: 17:54:00
2018-01-16 16:11:09.975 Nautical twilight start: 06:43:00 Nautical twilight end: 18:28:00
2018-01-16 16:11:09.975 Astronomical twilight start: 06:11:00 Astronomical twilight end: 19:00:00
2018-01-16 16:11:09.975 EventSystem: reset all events...
2018-01-16 16:11:10.106 PluginSystem: Started, Python version '3.5.2'.
2018-01-16 16:11:10.110 Active notification Subsystems: (0/14)
2018-01-16 16:11:10.115 WebServer(HTTP) started on address: :: with port xxx
2018-01-16 16:11:10.129 WebServer(SSL) started on address: :: with port xxx
2018-01-16 16:11:10.130 Proxymanager started.
2018-01-16 16:11:10.136 Starting shared server on: :::xxx
2018-01-16 16:11:10.137 TCPServer: shared server started...
2018-01-16 16:11:10.137 RxQueue: queue worker started...
2018-01-16 16:11:12.138 EventSystem: reset all events...
2018-01-16 16:11:12.138 EventSystem: reset all device statuses...
2018-01-16 16:11:12.170 Python EventSystem: Initalizing event module.
2018-01-16 16:11:12.170 EventSystem: Started
2018-01-16 16:11:12.170 EventSystem: Queue thread started...
2018-01-16 16:11:12.338 RFLink: Using serial port: /dev/ttyUSB-RFLink
2018-01-16 16:11:12.494 PluginSystem: Entering work loop.
2018-01-16 16:11:12.638 OpenZWave: using config in: /xxx/xxx/domoticz/Config/
2018-01-16 16:11:12.640 OpenZWave: Starting...
2018-01-16 16:11:12.640 OpenZWave: Version: 1.4-2888-g5468237-dirty
2018-01-16 16:11:13.263 RFLink: Controller Initialized!...
2018-01-16 16:11:13.339 RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2018-01-16 16:11:18.635 Incoming connection from: 192.168.1.59
2018-01-16 16:11:22.641 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
2018-01-16 16:11:23.642 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
2018-01-16 16:11:24.642 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
2018-01-16 16:11:25.643 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
2018-01-16 16:11:26.643 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
i try a lot of times, reset controller, reset node,change usb port, nothing change.
Schermata 2018-01-16 alle 16.19.09.png (98.17 KiB) Viewed 7443 times
ports seems right configured
since i d install rflink all gone ok, now with rflink i've this issue.
if i disable and (after reboot) enable it all back ok............
Cany you help me?
ps: why i've beta version? i follow official wiki instruction to install it :(
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
dextm80
Post by dextm80 »
1x Fibaro Wall Plug
Philips Hue Bridge
hestia
Domoticz version: 2022.1
Post by hestia »
dextm80 wrote: Tuesday 16 January 2018 17:19 look here https://www.domoticz.com/forum/viewtopi ... 4&start=20
Hello
The requested topic does not exist :-(
I still have this issue
I've read that it is something about a cache but I'd like to have something more specific if possible.
Version: 4.11361
Build Hash: 1872f7e5d
Compile Date: 2019-10-11 16:42:44
Same with previous betas
944Driver
Post by 944Driver »
My ozw panel is blank after last update. I can still see the devices in the domoticz view.
Domoticz V4.11415 Build Hash: 9bcb67547 Build Date: 2019-10-25 17:56:30
Any ideas on what to check?
// Magnus
hestia
Post by hestia »
Hello
I've installed 12815 and after the ozw panel is blank (it was ok before)
I've cleared the browsing data and removed the html5.appcache file.
Tested with several browser on different devices
Just upgraded to 12819 with no progress
What else?
hestia
Post by hestia »
it is ok now !!!
I did nothing... except waiting.
Perhaps, it needs some time ?
Strange anyway !?!
WLKe
Post by WLKe »
Check permission on ozwcp.* file in domoticz directory.
Must be domoticz writable.
