RFXCOM : Error opening serial port!
Posted: Saturday 17 June 2017 18:10
I am running Domoticz on a Windows 2012R2 (HP N40L) with a RFXCOM. Works perfect but after a couple of day (could 1 or 2) i get the following error
2017-06-17 18:01:46.208 Error: RFXCOM: Error opening serial port!
2017-06-17 18:01:47.223 RFXCOM: retrying in 30 seconds...
And this continues for ever.
The solution for this is stop the domoticz service, disconnect and connect the RFXCOM start domoticz again. After this everything is fine again (for a couple of days after the which the error returns)...
Any idea what is causing this.
What i also did when I get the error was stop domoticz and start RFXmgr to see if that application was abel to connect (also no luck).
