Zwave cannot find/activate node
Posted: Thursday 15 June 2017 22:09
by Chromoris
I've got an interesting problem.
Yesterday I stopped domoticz and updated both it and openzwave to the latest GIT version (aka the latest beta version).
I did this together with updating my system (running arch linux on a Raspberry Pi 3 with an Aeon labs z-stick gen. 5).
I then rebooted.
I've got one Z-wave node (Rookmelder woonkamer) that isn't waking up anymore to the network. It's a Fibaro smoke sensor v2. I've already pressed the buttons on the thing to wake it up, but no luck. I've also tried to heal the network, but no luck either.
I've attached 2 screenshots:
screenshot 1.png (345.41 KiB) Viewed 1456 times
the openzwave control panel: the sensor is not responding.
screenshot 2.png (377.35 KiB) Viewed 1456 times
the network topology: the sensor is no longer connected to the network (as far as I can see).
The sensor is almost next to a Nodon switch (Weerstation), so it should be in range of the network. Furthermore I've taken it next to the Raspberry Pi and tried to wake it up. I cannot get the thing to connect.
Does anyone have any idea as to how I can get this thing back online? Also I'm kind of curious as to how this could have happened.
My emergency solution would be to reset the device and then add it back into the network again, but I'm unsure as to what the consequences are of that action. Also taking out the z-stick and using it to remove and the add the sensor back into the network would be an idea. But considering that I've had no response even when bringing the sensor right next to the z-stick, I'm not very positive about this (also I'm concerned that when booting up the network, a similar problem could occur).
Re: Zwave cannot find/activate node
Posted: Friday 16 June 2017 2:10
by asjmcguire
OK so it's not a problem with the Device - for some reason the system has got stuck on that node in the CacheLoad phase - mine does this on rare occasions - with both sleeping nodes as well as awake nodes. All I do is go to the Domoticz hardware tab, disable the ZWave hardware for 5 seconds and then re-enable the ZWave hardware again. I find it is more likely to happen after a full system reboot - and doing this seems to fix it.
Posted: Friday 16 June 2017 14:56
by Chromoris
Tried it, but it didn't work.
I disabled the ZWave hardware, only for Domoticz to hang.
I've restarted Domoticz and enabled the hardware again.
Now I'm stuck with 2 smoke detectors who aren't responding anymore.
These things have network range test, and now neither of them can find the network again.
I'm going to downgrade openzwave, perhaps the fault is with the current version of it.
