I have a 1-wire setup and a DS2438 that gives humidity. Domoticz sees this fine and correctly shows me the humidity (63% at the moment). But if I push this value to influxdb (using http or the influxdb data push in the beta) the value sent is "3".
Any ideas why?
Cheers,
F.
Wrong value sent (Humidity from DS2438)
Moderators: fantom, leecollings
SweetPants
Re: Wrong value sent (Humidity from DS2438)
why post the same question 2 times? http://www.domoticz.com/forum/viewtopic ... 28&t=17952 I don't think you get an answer sooner
frstep
Because I don't know if the problem lies in the fact it is a 1-wire issue or data push issue... but don't let that stop you making replies that actually help find a solution.
