Does otherdevices['Domoticz Security Panel'] not work any longer? Topic is solved
Keleos
Post by Keleos »
Hello everyone,
does the following bit of code does not work any longer?
if (otherdevices['Domoticz Security Panel'] == 'Arm Away') then
because I do not get this code working:
tc=next(devicechanged)
MCS_switch=tostring(tc)
-- Pruefe den Ausloeser Name auf "Tuer"
if (MCS_switch:sub(5,8) == 'Tuer') then
    -- Ist das Domoticz Security Panel auf "Arm Away" gestellt?
        -- Eintrag in das Protokoll schreiben
        print('Oeffnung der Tuer erkannt an: '..MCS_switch)
        -- Ereignis in Variablen merken
        commandArray['Variable:LastAlarmDevice'] = 'Oeffnung der Tuer erkannt an: '..MCS_switch
        commandArray['AlarmDetected']='On'
        -- Benachrichtigung senden
        -- commandArray['SendNotification']='Oeffnung der Tuer erkannt an: '..MCS_switch
The Domoticz Security Panel State is ignored totaly :(
Greetings
jvdz
Domoticz version: 4.107
Re: Does otherdevices['Domoticz Security Panel'] not work any longer?
Post by jvdz »
Keleos wrote:Hello everyone,
Don't think that ever worked as that needs to be 'Armed Away'. ;)
I use this way to test it by the way:
if (globalvariables['Security'] == "Armed Away") then
Jos
Keleos
Post by Keleos »
thank you very much for your response :)
The strange thing, the following code enables and disables the Alarm Panel but I'm not able to get the state :(
Panel=tostring(tc)
-- Pruefe den Ausloeser Name auf "Keypad"
if (Panel:sub(5,10) == 'Keypad') then
    -- Die Variable "Security Panel" auf den Status des Keypads setzen
    if (devicechanged[Panel] == 'On') then
        print('Keypad Alarm-Status: Arm Away')
        -- Domoticz Security Panel deaktivieren
        commandArray['Domoticz Security Panel'] = 'Arm Away'
        print('Keypad Alarm-Status: Ausgeschaltet')
        commandArray['Domoticz Security Panel'] = 'Disarm'
        commandArray['Keypad Ack'] = 'On'
I'm trying to set up this description:
https://www.domoticz.com/forum/search.p ... sf=msgonly
Greetings
jvdz
Post by jvdz »
Did you try this using globalvariables['Security'] to retrieve the current status?
Jos
Keleos
Post by Keleos »
No, how could I do this?
Greetings
Kel
jvdz
Post by jvdz »
Not sure what you exactly want to do so please explain what you want to accomplish exactly with this the status value?
Jos
Keleos
Post by Keleos »
I just tested the global variable you recommended and it works wonderful :)
I try to test if the Domoticz Security Panel is set to "Armed Away", "Armed Home" or "Disabled" so every sensor recognizing a motion knows if he should trigger the alert.
Now I can continue scripting. Thank you very much :)
