ASA ETR Blids motor
Posted: Friday 09 June 2017 15:33
by duduf
hello, I have domoticz on my Synology with the RFXtrx433E. I have 3 shutters with ASA GO-4 motor. I try to add switch with the learning mode but it doesn't see anything. I am a new with this and I don't undertand how I can get the shutter on domoticz.
Did I have to do as for a somfy?
Can someone please put me in the good way?
Re: ASA ETR Blinds motor
Posted: Friday 09 June 2017 15:37
by b_weijenberg
Yes, use the same procedure as Somfy RTS to add the device in Domoticz.
You can also use RFXmngr to pair the AS motor and use the same ID-Unit code in Domoticz as used in RFXmngr.
Posted: Monday 12 June 2017 16:01
by duduf
b_weijenberg wrote:Yes, use the same procedure as Somfy RTS to add the device in Domoticz.
Oke thanks. I will try.
Posted: Monday 12 June 2017 17:18
by duduf
It works... thanks for your help
Re: ASA ETR Blids motor
Posted: Friday 17 July 2020 20:06
by jmadejek
Can You share your solution? I'm fighting with this few hours
